-   -   Stop using Elevator bolts? (http://www.airforums.com/forums/f36/stop-using-elevator-bolts-41216.html)
Forrest 04-13-2008 09:17 PM
Does anyone know when Airstream stopped using elevator bolts to attach the floor to the chassis?
My 1966 Globe Trotter and Overlander used elevator bolts, but my 1985 Excella uses self-tapping wafer head bolts.
Along that same line of question, when did Airstream switch from plywood to wafer board (or flake board)?
CanoeStream 04-13-2008 09:53 PM
I know this was a serious floor rot issue after it was introduced in '02 in the 22' Int'l. I believe that was also a one-piece floor without joints. John Irwin had one of those models during the brief 2 year period when that model also experimented with no belly pan. I believe it had a membrane above the frame but below the floor. My '06 Safari floor is plywood. What have you seen & heard built from wafer board?
Forrest 04-13-2008 10:07 PM
My '85 Excella has a wafer board floor. It looks good and solid (appears to be 3/4" thick). It must be an okay material to use as I know previous owners have towed the trailer from one side of the country to the other. It hasn't been a trailer parked in the back yard all its life.
Likewise, I'm surprised at how well the wafer head self-tapping bolts appear to be doing. However, I don't know yet if these were also used along the perimeter floor channel.
hadams 04-13-2008 10:17 PM
My '82 had plywood. The '86 has wafer board aka OSB I do not see mold or rotting.
