-   -   A/C Installation Question (http://www.airforums.com/forums/f427/a-c-installation-question-40590.html)
Ganglin 03-21-2008 10:36 PM
We had planned to install a Coleman AC - have used them in the past with no problems and they have an interior cover that better matches the ceiling shape.
Ran across a really good deal on a Carrier Low Profile so now I may be leaning that direction instead.
Talked to the dealer about installation in an Airstream and they said they had done it many times. The question - they said it was necessary to install a couple pieces of treated lumber between the inner and outer skins to reinforce the roof/installation. "you'll see what I mean when you pull the old one".
Has anyone done that - if so can you tell me what was involved....
goransons 03-21-2008 10:44 PM
yes we did, but I personally wouldn't use wood, we used 2" aluminum C channel. Basically the sheet metal needs "studs" to fill in between the skins, just basically like putting a new opening in a house.
we documented the install here:
http://www.airforums.com/forums/f427...day-35176.html
Ganglin 03-21-2008 10:59 PM
Thanks - so this pic is the C channel you used instead of lumber..?
http://www.airforums.com/forums/atta...6&d=1187395584
goransons 03-21-2008 11:07 PM
Yes, I cut the hole where Inland Andy said to, which left a few inches towards the front of unsupported skin, and a foot plus behind it, then side to side also. I made 2 of them attach to the existing framing, then the two that go front to back attach to the newly installed ones, so the skin was not holding the blocking in place, the frame held the blocking, then attached skin to new blocking.
markdoane 03-22-2008 04:58 AM
I agree, don't use treated lumber in contact with aluminum. There are copper salts in some treated lumber that will cause corrosion problems.
I did the same aluminum framing that Goransons used. Here's a link.
juel 03-22-2008 06:46 AM
Now, where is this great deal on the low profile?
markdoane 03-22-2008 06:51 AM
Palomino. Talk to Jevin.
lewster 03-22-2008 08:07 AM
Not to spoil your fun...............
................BUT...................
I've had nothing but problems with warranty service from Carrier. Yes, they make a nice unit but I will no longer service them under warranty because they do not pay in a timely fashion and have a very, very poor response to tech support questions.
IMHO, you should carefully weigh this into your purchase decisions.:cool:
Ganglin 03-22-2008 11:45 AM
Now You tell Me
Lew - I just chunked out $725 minutes before seeing your reply...!!!
Well - I've made my bed - so not much I can do about it now. If you really don't think this is a good unit I could trying calling the dealer on Monday and see if they will let me apply the cash to a different unit? It's Family RV in New Port Richey, FL.
Link to the item on Ebay.
eBay Motors: NEW LOW PROFILE CARRIER 15K RV,AC,BOAT,AIR CONDITIONER (item 160218588828 end time Mar-24-08 02:47:08 PDT)
goransons 03-22-2008 11:58 AM
We've had our low profile for a year now, and love it so far, though must confess we haven't had a warranty issue to date (knock on wood) and also got ours through family RV on ebay (arrived in 24 hours). Hopefully if we have issues a local dealer won't have yet had that kind of luck processing warranty claims or carrier has fixed the problem. We've been very pleased with that purchase so far so don't kick yourself too hard.
Ganglin 03-22-2008 12:25 PM
Thanks - it's good to hear that. Hopefully we'll have good experience with it also. I use A/C so little it won't take much of a beating.
adonh 03-22-2008 04:09 PM
I to went with the Carrier AC a few years ago, no problems at all. I have the 15,000BTU unit and it will keep you cool. The only complaint that I have against the Carrier is the fan speed. Its 2 speeds, Hi and Higher. No real low speed for those times when you need just a little cooling.
Also on my 76 for the curved inside ceiling I built a spacer that fits the curved ceiling and then provids a flat surface to mount the cover. The spacer is a separate piece that is bolted on with the long bolts that hold the unit down. I think I have some pictures and will post them if I can locate them.
Also, the Carrier has a small pan at the bottom of the fan that allows the fan to sling the condensation and in theory less water runs down the side. I had a small brass fitting attached to the bottom of the pan and then hooked up my old drain line that was used for the old Armstrong and no water running down the side.
Don
1976 31' Sovereign
Ganglin 03-22-2008 04:54 PM
Don,
I'd be interested in how you did the spacer. One of the reason I originally thought about the Coleman was the curved inner cover. The dealer mentioned they have taken the Carrier and cut it down with a Dremel to match the ceiling - not sure I want to dive into that. Their other solution was to cut a piece of foam from the packing material to place in the gap.
goransons 03-22-2008 05:07 PM
I don't know if the 71 still has the seperate panel down the center on the ceiling with the two channels for wiring, but if you look in the pics on our install you'll see we had just a piece of poplar with miters on each end. I little caulk and painting the ceiling it all blended in very well and lets teh bottom unit stay its true form without distorting.
Ganglin 03-22-2008 05:21 PM
It looks like this - in fact this is the same interior cover I have now....
http://www.vintageairstream.com/arch...lides/9c_3.jpg
adonh 03-23-2008 11:48 AM
Here is picture of the spacer that I built. I designed to fit up to the ceiling by making a template from the light fixture to match the curve of the ceiling. It has the 14" cutout to match the hole in the roof for the AC and the inside unit is mounted on the flat side of the spacer with the 4 long bolts that hold the outside unit down. I tightened these bolts to achieve the required compression of the gasket that fits between the outside unit and the roof. Then the cover is attach to the inside unit which is mounted to flat surface of the spacer. The spacer when pained a matching semi-gloss color in the same shade (mixed by Sherwin William's using the cover as a guide) it looks like it came with the AC. I have had people tell me that their Carrier did not come with this piece and want to know if it is a special order item. I don't have the A/S home now but should have it here next week and will take some more pic's with the cover off.
Don
vswingfield 03-23-2008 11:54 AM
Thanks Don,
I look forward to more photos. How about some big ones that we can click on for more detail? What did you make the spacer from? I am installing a Carrier on my Excella, hopefully next weekend. I would especially appreciate details of your drain attachment, since I have been considering the same thing. Hey, I’ve already got the line!
That’s a nice part of the country where you live. I’m also glad to hear the 15,000 unit is keeping you cool. My 34’ Excella was warm last summer, and now the old Coleman will only run about 2 minutes before cycling.
Ganglin 03-23-2008 12:42 PM
Don, That does look really good from what can be seen. If you could post some more pics of your work that would help. Thanks....
Don
adonh 03-23-2008 02:31 PM
I should have it home by Tuesday and I will take some more pic's of the spacer and the drain. I will make them a little larger so that you can see more detail.
Don
Inland RV Center, In 03-23-2008 02:35 PM
Don
Making a spacer is not required, and a big waste of time.
Simply use the same material the surrounds the "vista view window" cutout.
We have used that material for 20 years for that purpose.
Slide it up or down as needed over the shroud.
