-   -   Husky vs Robin vs Reese / Drawtite Hitches (http://www.airforums.com/forums/f464/husky-vs-robin-vs-reese-drawtite-hitches-38889.html)
flyfishfred 01-09-2008 01:10 PM
Well i just talked to my trailer pick up dealer and he says they are currently using Husky and Robin weight distribution/sway control hitches,which i don't think anyone has discussed on these forums. I still want to go with the Reese (straight line/dual cams)which they can get , but was curious if anyone has used these other hiches, and if so what do you think about them ? Thanks
Fred
overlander63 01-09-2008 05:21 PM
Strangely enough, I have used both. They are both lower-budget, made overseas hitches. From my experience, the Husky is somewhat better than the Robin. The Robin that I had was kind of sloppy, both fit-wise, and for longevity. I had to continually play with the head to get it to stay where it needed to be, it kept loosening while towing, and moving on me.
the Husky only needed to be adjusted into position once, and I never had to mess with it again.
flyfishfred 01-10-2008 01:52 PM
Hey Terry, thanks for reply.
Thats what i kinda thought (lower- budget hitches). This dealer usually includes hitch price/install when you purchase a rig from them. They get the best bang (for them) probably from lower priced hitches. My hitch was not included in trailer price so i have option of selecting exactly what i want. :)
Fred
Sean Woodruff 01-10-2008 03:30 PM
Fred
Fred, that is the way to buy a hitch. I have seen the issue get confused too many times to count when the hitch is "thrown in with the deal." Unfortunately, when that happens, the hitch is usually the cheapest cost hitch availble at the time regardless of the brand.
overlander63 01-10-2008 04:17 PM
I've seen that also, and probably the best answer to this would be to ask for that amount of money off the price, and you can use that toward the hitch of your choice.
