-   -   Switch above refrigerator in 67' safari (http://www.airforums.com/forums/f447/switch-above-refrigerator-in-67-safari-38746.html)
Adair 01-04-2008 01:41 PM
Howdy,
67' Safari, one switch above refrigerator, another electrical box with a curious little fixture on the cover plate. I have no idea what either is for. It would be swell if it had something to do with the water pump because right now I have no continuity at the pump.
Cheers, Adair
Melody Ranch 01-04-2008 01:54 PM
Your in luck
Yep! Its for the water pump. You can get the replacement pumps inexpensively on EBAY.
Adair 01-04-2008 02:00 PM
Thanks M.R.
I have multiple back up pumps. I'm enamored with the little reciprocating guys. My pumps work fine, I just didn't have any juice. At least now I can track down the break in the line a bit more easily, or maybe it is as simple as a loose connection at the switch.
This place is great. I had an answer in five minutes.
Now what is the other deal next to the pump switch?
-A.
TomW 01-04-2008 03:29 PM
My '67 Airstream had four things around that general area:
120 vac outlet
Switch for water pump
12 vdc outlet (looks like a cigarette lighter)
Television antenna outlet (three, small, triangularly-spaced, 1/8-inch D holes on a plate)
Tom
Adair 01-04-2008 09:18 PM
Had one loose wire to the water pump switch. Now the pump is going fine.
Looked at the curious plate I was inquiring about. Pulled on the tab that projected out...and it slipped right out of its socket. The male side of this was in the wall socket; two prongs. The female side was in my hand and it had two copper sleeves. I really don't know what it is, but perhaps as TomW mentioned it was related to the TV since the shelf above the fridge seems to be popularly understood as a TV shelf.
Many thanks to you all. Tomorrow I will fill up my water tank for the first time and have pressure. Wintering in a trailer without running water has been exciting the last couple of weeks.
A.
