-   -   broken ceiling light toggle switch (http://www.airforums.com/forums/f447/broken-ceiling-light-toggle-switch-34499.html)
ole81 07-22-2007 08:05 PM
Hi Folks,
Can anyone shed light on how to remove/repair/open a ceiling light toggle switch? today I switched it on, and am unable to toggle it off. I had to remove the cover and remove the bulbs so that it would not drain my battery.
Thanks.
Bob and Gail
31' 1981 Excella II
2001 F250 Crew, 8' bed, Pullrite hitch.
Ganglin 07-22-2007 08:11 PM
Any chance you can post a photo of the offending switch....
ole81 07-22-2007 08:56 PM
picture of stuck switch
Thanks for the quick reply.
Am attaching a picture of the switch..
The base (touching the ceiling) is a slightly darker shade then the toggle and its surround.
Bob and Gail
WayWard Wind 07-22-2007 09:02 PM
slide something flat and thin behind the large outer cover and GENTLY pry the cover away from the switch section. This will expose the switch it's self, which is fasten to a bracket of sorts. From there you can fix and/or replace. Be gentle and go slow.
Best,
Inland RV Center, In 07-23-2007 03:53 PM
Bob and Gail
Unfortunately, that switch has not been available from Airstream for some time.
Pop Rivet 07-23-2007 04:15 PM
Bob and Gail
Lucky you - I have a couple you may have - The outer frame measures 2 and 1/4 by 1 and 3/8ths inch. No lettering on toggle. PM me an address and I'll send them to you.
