-   -   Wfco 9865 (http://www.airforums.com/forums/f449/wfco-9865-a-34261.html)
Sundance 07-15-2007 04:04 PM
Wfco 9865
I pulled the UniVolt from my Argosy and have purchased the 9865.
After reviewing the manual I see that I am going to need to fabricate or buy a small buss bar/box to distribute the load. (old panel is with Univolt).
It is a simple buss with 6 lugs. 2 go to the battery and there are 4 DC circuits.
Where can I find a small unit?? Everything I see has a dozen or more lugs and way to "fancy" than I need.
Also, I don't see a seperate circuit for the battery.......... How is the battery charged by the WFCO??
As usual...... Thanks for the great advise.
Sundance 07-15-2007 04:23 PM
After browsing ebay I came across this. It has one input and 4 outputs.
Any reason this would not work??
eBay: Tsunami FDB1004-MANL (4) Pos Digital Distribution Block (item 250143380812 end time Jul-22-07 12:38:03 PDT)
TomW 07-15-2007 04:32 PM
That's alot of bling with a price tag to match.
It will work, but you can do more for less money.
Tom
Sundance 07-15-2007 04:42 PM
Please elaborate Tom......... cheap is my middle name.......
68 Overlander 07-15-2007 04:53 PM
This is what you need. The 9 position is $36. Look at the 2nd page of that pdf and it shows a typical installation for a deck mount converter and fuse block. Let me know if you need help.
Sundance 07-15-2007 05:28 PM
That is fantastic Overlander........ WFCO could learn from that.
Pop Rivet 07-15-2007 06:27 PM
Thrifty is good
Go to your local "pull it your self" automotive salvage yard. probally a buck or two
68 Overlander 07-15-2007 07:33 PM
They probably have no interest in producing one. We are their largest distributor and it's never even come up. The Parallax boards are very popular for Airstream owners upgrading the Univolt but by no means the only option. Some of the other manufactures we've talked to have similar boards but they are not popular like the FB9 so we don't want them sitting on the shelf.
The problem with converters today is that nobody produces one that is similar in design with ONLY the DC distribution connected to it. All of the power centers include AC and DC and are not deck mounts but rather wall mounts.
A good example for a deck mount even more popular than the Univolt is the old 3200 series Parallax found in 10s of thousands of old RVs like the Univolt in Airstream. Some had fuse boards on the end and some did not. If it did and your need to replace it, you have to purchase the fuse board separate and mount it on the wall next to it and run the old wires to it. Not a big deal either.
Sundance 07-15-2007 08:23 PM
The WFCO is a deck mount as well. I do like the car junk yard idea.......
Thanks all!!
