-   -   Leaks (http://www.airforums.com/forums/f446/leaks-33857.html)
Sundance 07-02-2007 06:23 PM
Leaks
I finally got my newly acquired Arogsy hooked up to water. Some minor problems.
1. There is a small leak coming from where the toilet meets the elevated platform. Do these have wax rings??? It must be a faulty seal of some sort.
2. The faucets are all original and in need of replacement. Are they obtainable?? Can you use something from Home Depot and the like??
53flyingcloud 07-02-2007 06:31 PM
Sundance..
Check ur valve in the toilet. COLD WEATHER VICTUM, I'LL BETCHA.
For all the rest,...here's a place to go wild..
GO-RV.com - RV On-line Catalog
or, for your example...
good luck..53FC
Sundance 07-02-2007 06:58 PM
How do you check this valve
Ganglin 07-02-2007 08:42 PM
Sundance - what toilet do you have.
The faucets can be rebuilt if you want to maintain the original ones.
53flyingcloud 07-03-2007 02:47 AM
Sundance,
The easiest way is to reach around to the opening in the back and feel water running down from the valve when flushed..(On most models, it's located just between the hinges for the seat lid.) The cheapest fix it is to put in a by-pass. That's the hardest part..You need to remove it to a table bench to replace the valve..Barring that, You're faced with a new unit replacement cost..It's a often sad reminder that we forgot ..that, when winter, comes to do a thoroughly intensive winterization. Happened to me some years ago..
Once you get it fixed..come this fall, after you drained the system completely..I suggest blow the system out with compressed air..you then put a plastic drink bottle upside down in the neck of ur toilet..(keep a string around it~!!)
ciao
53FC
