-   Leaks - Weatherstrips, Gaskets, Caulks & Sealants (http://www.airforums.com/forums/f456/)
-   -   Vulkem 611 vs 636 (http://www.airforums.com/forums/f456/vulkem-611-vs-636-a-33453.html)
dikku@mac.com 06-20-2007 09:56 AM
Vulkem 611 vs 636
Oops. I used vulkem 611 instead of 636 to seal the new water heater on my AS. Any major problems with the substitution? It's all I could find locally.
dik
malconium 06-25-2007 01:38 AM
I believe that I read somewhere that the formula for 611 works fine for an Airstream. As I recall the difference is that the texture is a little more grainey looking. That is so that it works well with masonry and looks more like grout. I have used some on my unit and sofar all is well.
Malcolm
davidz71 06-26-2007 10:33 PM
If you got the grainier Vulcum then keep your eye on it. I tried some and within a year it started to deteriorate. I have used Trempro 635 from Vintage Trailer Supply which leaves a slick/shiney rubbery finish.
