-   -   Floor replacement thickness (http://www.airforums.com/forums/f36/floor-replacement-thickness-30825.html)
soldiermedic 03-15-2007 11:09 AM
I know that there have been many threads on this but I did not find one unique to my question. I had a new frame fabricated for my 68 Safari, and with it goes a new floor. The current plan is for 1/2" Marine grade plywood. I keep reading that most people have 5/8. Will this 1/8 thinner piece of plywood have a detrimental effect on the coach's floor? There is going to be some kind of flooring laid on top of it after installation, but I have the chance now to change the floor (It will cost me about $400), but should it be done?
Steve
Wabbiteer 03-15-2007 11:28 AM
What spacing did the frame cross-members get installed at? 24" is a long gap to bridge with 5/8" or 1/2" plywood. I would be tempted to go oversize another step to 3/4 even if the edges then require removing thickness to clip into shell framing. I have a rear bath section that will be coming out this spring (5 days until spring, I'm in trouble) and will be shopping plywood pretty hard too...
Aerowood 03-15-2007 11:33 AM
My 71 Globetrotter had 5/8 and I upped to 3/4. New floor is much firmer then the old. No regrets
markdoane 03-15-2007 11:50 AM
My '59 Tradewind was 5/8". I upgraded to 3/4", then added a moisture barrier and 1/4" pine underlayment. Next I will add 7/16" cork.
I'm glad I upgraded the axle.:blink:
LI Pets 03-15-2007 02:24 PM
I used 1/2".
But understand something about marine plywood.
Your wasting your money!
The only difference between marine and exterior grade is that the inner plys of marine have no knots from voids.
The glue is the same.
In a boat it matters.
In our use it is not required, buy exterior.
Jim & Susan 03-15-2007 02:44 PM
I used 3/4" exterior grade. That's what mine came with from the factory. I considered marine grade, but it was 2 to 3 time the cost. Which ever one I decided to use, I was going to treat it with epoxy and Varathane, regardless, so I opted for the cheaper plywood.
FreshAir 03-15-2007 02:46 PM
I am now completing my installation of the rear bath floor in my '66 Trade Wind. I decided to stay with the 5/8 thickness as the new would be butting up to the old. The 5/8 seems adequate in my AS. The remainder of the flooring is pretty solid.
Neil.
bobkelly 03-15-2007 05:22 PM
Floor thickness
Congratulations on the new frame for the restoration. The thickness of the plywood is very significant to both the performance and feel of the floor. If your new frame was designed specifically to support 1/2" plywood, great. The supports for the plywood will be closer together than for a thicker floor.
If not, a 5/8" floor is 25% thicker than a 1/2" and will deflect much less when walked on.
soldiermedic 03-15-2007 06:53 PM
Wabs, the spacing is identical to the original frame. I had them recreate the frame to the same specifications so that everything word work out well. I originally got the 1/2 inch because that is what I assumed it was after looking at it. Stupid me to not measure until I had already gotten the supplies. If Bob has used 1/2 inch and it turned out ok then I should be ok. It will have another layer over it anyhow so I am not to worried about it.
Steve
LI Pets 03-15-2007 07:27 PM
You said another layer, of what?
soldiermedic 03-15-2007 09:01 PM
Some kind oflaminate or hardwood flooring. If I need I can add a layer of luan over the subfloor.
uwe 03-15-2007 09:12 PM
Ah, I don't think 1/2 in is a good idea. It will deflect a lot when you walk on it, and it will detract from teh original strength of design. 5/8 was original for your trailer.
Even if you put a solid material on top, it will still deflect quite a bit. Makes the trailer feel spongy.
I used 5/8 and wish I had gone to 3/4 for my Overlander. It has a cork flooring on top, and it still deflects a bit.
LI Pets 03-15-2007 09:37 PM
My method, use the 1/2", don't use layer of any type of heavy wood that can absorb moisture.
Just get 6 oz fiberglass cloth on top of the wood with epoxy resin,
then (well wait till it dries) jump up and down tell us how much it flexes.
I'll make you a bet it won't be much at all well within specs.
If you add a pergo type floor over that then try it with an 800 lb gorrilla:lol:
You will save a lot of weight and have a bullet proof floor.
You can buy the fiberglass and MAS epoxy at Jamestown boat supply in RI, at good prices.
soldiermedic 03-16-2007 08:56 AM
Did the fiberglass and resin add more weight then the extra 1/8th inch of wood from the 5/8th?
