-   -   Stabilizer shock (http://www.airforums.com/forums/f159/stabilizer-shock-30038.html)
john roeder 02-11-2007 05:58 PM
Stabilizer shock
Need to replace this shock-steering stabilizer, it's leaking. Just wondering about the end that goes into the frame. I can't find a way or even see the nut because of the frame work. Is it welded to the frame so all you have to do is screw the old out and the new in. Also the other end sure is hard to get out but i will get, never give up. Thanks to all.
Fyrzowt 02-12-2007 03:55 PM
John,
Not sure of your model, but typically there is an access hole on the back side of the frame where the nut is located. If so, use a socket with extension with an impact wrench if you have one. Hope that helps...
Dave
Robfike 02-16-2007 05:42 PM
Bilstein makes a great replacement unit for these.
Rob
911rs 03-07-2007 11:50 AM
Bilstein Part Number?
Anyone have a part number for a Bilstein stabilizer shock for a 1975 Argosy 20 350 engine? Thank you
Robfike 03-08-2007 07:53 AM
Go to Bilstein Shocks, Edelbrock Shocks and more: eShocks.com They show the part number as BE3-2645-H0.
This is only one of the online shock outfits. I replaced all of my shocks and the steering stabilizer with Bilstien. (Except the tag shocks, they have to come from Andy)
Rob
911rs 03-08-2007 08:43 AM
Thank you Rob.
Robfike 03-09-2007 06:01 AM
911RS,
Does your online name mean you have a 911RS? I road race a 911 in GT-3 class, and drive a '76 912E on the road.
Last summer I had the 345's hitch upgraded to be able to tow the race trailer. (7000#)
Rob
