-   -   toilet seal (http://www.airforums.com/forums/f446/toilet-seal-29945.html)
cookeville34 02-07-2007 07:54 PM
toilet seal
Does the toilet in my 1979 AS need a wax seal or sealant around the base? I pulled the toilet to replace the carpet in the rear bathroom and noticed the toilet had been leaking. It appeared it had some kind of white sealant around the flange, but its dried up and hard as a rock. Thank you.
overlander63 02-07-2007 08:00 PM
Every one I have removed has had a soft foam (at least it was soft when installed) ring, and should be replaced before re-installing the toilet.
