-   -   Replacing Coleman Delta TX 13500btu A/C (http://www.airforums.com/forums/f427/replacing-coleman-delta-tx-13500btu-a-c-25441.html)
tr674 08-21-2006 10:03 AM
I am replacing my old ac with a new Coleman 15000btu unit,
can I use the same drip pan? :flowers:
breakaway 01-02-2007 08:19 PM
Does anybody know?
Thinking ahead to this summer.... my Delta TX is also not working and I feel it needs to be replaced. Can the current drip pan be reused? What is the right A/C unit to purchase?
capt ken 08-17-2014 09:53 AM
delta tx replacement
I have the same problem. replacing the delta tx with an AC that will fit the hole pattern in the drip pan.what did you do to fix the problem? I cant believe there is no one out there that can steer us in the right direction. Do they still make the delta tx? Ken
esmaytum 09-23-2014 09:50 PM
Get the Coleman Mach 8 low profile 15,000 btu. It has an internal drain pump so you don't need a drip pan. It works really well.
