-   -   Generator filters (http://www.airforums.com/forums/f159/generator-filters-2313.html)
ViewRVs 10-30-2002 03:15 PM
Kohler Generator filters
My local shop wants $16.44 per air filter and $13.28 per oil filter for my Kohler generator. Is that high or par for the course?
Is there a cross reference to a national brand that I can get for less?
(Kohler 7C M21)
ViewRVs 10-30-2002 03:23 PM
Belay that order number 1....
Discount Auto Parts cross-referenced them as follows:
Oil - Kohler 277233 to Fram PH3600
Air - Kohler 47-083-04 ($16.44) to Purolator A23340 ($6.29)
74Argosy24MH 10-30-2002 05:40 PM
Fred
I have a single cylinder Kohler engine that sees a lot of dusty use. It uses the same air filter as my 7000w Kohler generator, round about 8" diameter. I got foam sleeves from the Kohler dealer that can be oiled, washed and reused. I haven't had to replace the paper filters in 3 years, was changing the one every other month.
Astrodokk 04-05-2004 12:07 AM
Onan 4.0 genset air filter
Where can i buy these? The one in there now looks like it's the original...brown paper! Rusted metal. Not too good maintenance by the PO!
Astrodokk 04-05-2004 12:10 AM
LPG conversion
Astrodokk 04-05-2004 12:11 AM
Oil fill area: must have spilled alot!
thenewkid64 04-05-2004 06:02 AM
Best bet is gonna be CW on bot the Air and Oil Filter unless you have a Cummins dealer close by. The Oil Filters can be cross referenced, but the Air filters are a unique part.
wb13798 04-05-2004 09:17 AM
gen set filters
try NAPA just replaced my filters and they had the correct parts. no sponge outer cover just a paper filter. oil was 8 and air was 6 . need to know the model for the set . my gen set is a nhe or nhel for parts. don't know what a Kohler would be, look on the tag. that is how he looked the parts up.
