-   1960 Pacer (http://www.airforums.com/forums/f119/)
-   -   Weight of Pacer? (http://www.airforums.com/forums/f119/weight-of-pacer-22607.html)
quinn 05-09-2006 04:23 PM
Weight of Pacer?
hi. i was wondering if anyone knows the weight of the 1960 pacer. and also what sort of tow hitch it takes. we are buying a ford explorer and wondering if it will tow the Pacer. any help?
thanks
RichardT 05-09-2006 06:41 PM
It is not on the Weight chart, but my guess would be about 1900 pounds.
peregrine 05-09-2006 09:38 PM
Pacer weight
My findings find pacer wt to be 1750 empty, I'm using a 2001 ford explorer to tow with, max tow wt of 5500 lbs, so I've had on problems.
quinn 05-10-2006 10:04 AM
thanks... now for hitches....?
thanks! now, any advice on hitch and tow vehicle? we have access to a 1991 ford explorer, which i am really hoping will tow the pacer. if so, will the reese hitch do well enough with a trailer that size? thanks again.:)
Chuck 05-10-2006 11:33 AM
(off topic) great username for an "airstreamer"! (and welcome to the forums).
here's some trivia: the first child born to the pilgrims in the new world was named "Peregrine".... http://www.pilgrimhall.org/whitep.htm
(allegedly, an ancestor of mine. talk about a salty old newenglander, eh? :rolleyes: )
AYRSTRM2 05-10-2006 11:41 AM
Yes, that set up will be fine; Depending upon the engine in the explorer. Make sure to check your users manual with the Explorer. Also, DO NOT, UNDER ANY CIRCUMSTANCES, use the "bumper" hitch. You must use a frame mounted receiver type Class II hitch. Most will tell you to use a light weight distribution hitch. Don't know much about the ones for that light of a trailer. Hopefully someone can talk about very light WD hitches.
Perry 01-24-2008 04:12 AM
Weight Pacer
Hi
So that is the empty weight, do you know full load weight
thanks
perry
Ahab 01-24-2008 08:54 AM
We towed a PU weighing in at 2800# full up, with a '89 Exploder V6. Draw Tite class III hitch, no WDH or anti-sway, never had any problems.:)
