-   -   Carbon Monoxide detector (http://www.airforums.com/forums/f46/carbon-monoxide-detector-202839.html)
montgomg 11-12-2019 03:47 PM
2018 Flying Cloud in storage indoors on our property with a battery maintainer on the batteries.
CO detector is chirping every 40 seconds or so. I understand this to be a low voltage alarm (somewheres below 12 Volts).
When pushing the test button 5 louder chips occur in just a second or two.
I have plugged the Flying Cloud into shore power (120AC) waited a couple hours and the 40 second spaced chirping continues.
Any thoughts on what the problem may be?
SilverWind 11-12-2019 03:53 PM
Many hard wired CO detectors also have a backup 9 volt battery inside the unit.
Baby Zeppelin 11-12-2019 04:02 PM
I just had to replace the 9v batteries on our 2018 Flying Cloud's smoke detector and CO detector. Both started chirping the same day.
The propane detector is hard wired, and I put a switch in it's circuit after it wouldn't shut off. The detector was replaced under warranty in JC, but I keep the new one switched so I can readily shut it off if it starts behaving like the original one. The switch is inside the cabinet next to the detector so there is no fear of shutting it off unknowingly and being unprotected.
montgomg 11-12-2019 05:04 PM
Thanks for the replies. I had not considered a battery backup but it makes sense.
The manuals and docs which came with the airstream (we bought it new) made no mention of battery backup. Pretty standard!!
overlander63 11-12-2019 07:06 PM
Your trailer does not have a 12v CO alarm. It is 9v only. The chirping is letting you know the battery requires replacement.
Baby Zeppelin 11-12-2019 07:57 PM
One thing not real obvious is which way the new battery goes in the CO detector and in the smoke detector. It's not marked + and - , but one of the terminal receptacles is square and one is round. The larger of the battery terminals fits in the square hole, the little round one in the round hole.
bweybright 11-12-2019 08:19 PM
I would venture a guess that somewhere in all the material you got with the trailer is a little tiny sheet from the CO detector that tells you it needs a 9 volt battery. Most likely a 3 by 6 inch tri-folded sheet of paper or something like that...you know the ones you get in your smoke detector and CO detector from big box stores for your house and throw away (at least I do). I know Airstream gave me every single little bit of paper from the vendor sourced equipment. But it is fun to blame Airstream for everything I guess.
