-   Audio, Video & TV (http://www.airforums.com/forums/f450/)
-   -   Antenna leak (http://www.airforums.com/forums/f450/antenna-leak-202183.html)
natedogg7 10-22-2019 11:43 AM
Antenna leak
So I've completed a strip and prime with Pro-cryl and expected everything to be sealed up with 2 coats of acrylic primer. After heavy rain I found a leak coming right down the antenna crank. 1 can of flex seal later I though the problem was solved. 6 hours of rain on the maiden voyage and we stayed dry, yey! Then a torrential downpour yesterday morning showed I still have water coming in the antenna crank. 74 argosy pic attached, Any suggestions?
perryg114 10-22-2019 02:09 PM
I expect there is an O-ring in there that seals the shaft. Take it apart and find the seal.
Perry
Strangmoor 10-22-2019 05:43 PM
Do you / did you use the crank between when it stayed dry and the latest rainstorm when it leaked?
Maybe it loosened up or vibrated a gap in the flex seal. Try more! :)
Rob
natedogg7 10-22-2019 06:19 PM
Perry
Thank you
perryg114 10-23-2019 07:00 AM
Also there is a plastic weather seal that covers the mechanism. If that is missing it might leak more but I think mine has been gone for years and it does not leak.
Perry
