-   -   Where is the propane tank on a 2010 Interstate? (http://www.airforums.com/forums/f240/where-is-the-propane-tank-on-a-2010-interstate-202069.html)
jonmarinello 10-18-2019 04:47 PM
I need to change the Manchester Tank G12846 LP Gas Tank - Remote 90 OHM Sender which I am told is the correct model sender. I've crawled under the rear of the coach and don't see it.
jonmarinello 10-19-2019 03:52 PM
Think I found where it is
Looks like it might be under the passenger side twin bed at the forward end. My interstate has the Airstream fulltime bed conversion so I need to pull up some wood plates to check for sure.
Pahaska 10-19-2019 04:58 PM
Simply start at the fill port and follow the propane lines from there to the tank. I think you will find it forward of midships in the center of the coach.
jonmarinello 10-19-2019 09:07 PM
Thanks for getting back to me.
That's how I started but the lines go up and into the coach but below where you can see them in the coach. Tomorrow I will remove some of the fulltime bed wood panels and continue to follow them. Prior to that I will crawl under the coach and see if it is in fact forward of midships under the coach.
Titus 10-19-2019 09:18 PM
Try following back from the generator. That hose should be entirely underneath the chassis.
Pahaska 10-19-2019 10:40 PM
The safety codes require that, except for individual feed lines for the stove, furnace, and water heater, all lines must be outside of the coach. I think what you are seeing is a tap entering the coach to something like the stove. This applies to trailers and vans.
Airstream would never have disregarded the safety codes.
