-   Full-Timing, Winter Living & Workamping (http://www.airforums.com/forums/f459/)
-   -   63 Overlander question (http://www.airforums.com/forums/f459/63-overlander-question-201104.html)
MRJones 09-21-2019 07:09 PM
Hi folks, this is my first time posting on this forum. Iím looking for some information about my 63 Airstream Overlander. I bought it last year as kind of a second home while I help out with aging parents. It was delivered to me by the previous owner and we set it up at my parents house with its own sewer line. I had a problem with smell and I read in the manual that even when hooked up to sewer I should still close the tank and then empty it as needed. My problem is the pin that opens and closes the tank (on the outside) seems to be stuck. Iím not sure iif itís in the open or closed position. Any ideas? Has this ever happened to anyone on this forum? Iím going to have to fix this before I move the trailer when the time come.
HiHoAgRV 09-21-2019 08:50 PM
These vintage trailers had a brass dump valve that is notorious for leaking and sticking. Kind of a 2X strike before walking to the plate.
Yup, the black tank needs to stay closed until time for all the Ďcomponentsí to swoosh out in a rush so the solids get a free ride in the liquid. Unfortunately the leaky valve just leaves Mount Black Stone to crustify into a B grade movie horror.
The best solution is to adapt a new valve, Vintage Trailer Supply had a kit to do such.
Good luck!
