-   Doors & Locks (http://www.airforums.com/forums/f453/)
-   -   Bulletproof the modern inside door handle (http://www.airforums.com/forums/f453/bulletproof-the-modern-inside-door-handle-199246.html)
GMFL 08-07-2019 08:11 PM
6 Attachment(s)
This has been done before, but I thought I would document the process for reference sake.
We have all heard the horror stories of the inside door handle breaking off in ones hand helplessly locking the person inside their trailer.
Some of us have done the door pick MOD involving strategical drilling a hole in the screen door that allows you to “pick” the latch and exit the trailer in the event the door handle does break off in your hand. Here’s a link to that thread.
http://www.airforums.com/forums/f453...od-150277.html
Now let’s look at why the door handle breaks and how to help prevent it.
Why? Because it is cheap potmetal casting
How? The door handle and metal “trip mechanism are held together with a with a swaged joint, in which a square end of the handle is inserted into a square hole of the mechanism and swaged or flared to hold everything together. Overtime the use of the door handle to open and close the door causes this swaged joint to become loose and eventually break.
Solution:
By drilling and tapping the end on the door handle you can add a washer and machine screw to the end of the handle significantly increasing the strength of the joint between the door handle and trip mechanism. This machine screw and washer prevent the handle from wiggling which will prevent the degradation of the swag joint.
I drilled and tapped my handle for a 10-24 x3/4” machine screw and used a couple of washers ( one to fit over the handle end and one to hold everything nice and tight. I also added a few drops of loctite to the machine screw to prevent it from loosening over time.
See photos below.
A W Warn 08-07-2019 08:25 PM
This is something I should do on mine. Thanks for the description and photos!
GMFL 08-07-2019 08:27 PM
Welcome.
This hole is already there just needs to be drilled out to proper size and tapped.
GMFL 08-08-2019 05:43 AM
Here is the correct link to Rob’s (RFP) door pick MOD.
waninae39 08-08-2019 06:36 AM
i tried that , but the head of any screw i tried i too proud of the surface.
it then interferes when i try to re install the plate
i tried to grind the screw head, still to proud.
your door must have more clearance than the one on my as 22fb bambi
Mollysdad 08-08-2019 07:19 AM
See photos below.
Thanks for the fantastic photos!
I see how it goes together now. I also looked at the black casting part of the lock assembly. It looks like it's made so it can be used either right or left.
There's plenty of room to add an additional grab handle. I'll credit 'sheriff1' with the idea. Most cabinet handles have 3" spacing on the screws. A cabinet pull plus some small washers make a pull that will clear the screen and give you an additional pull instead of the stock lever.
https://i.imgur.com/lPqPVcC.jpg
rowiebowie 08-08-2019 07:31 AM
Sad that such a mod is even necessary. Especially when a case could be made for it being a safety hazard which warrants a recall.
sallye 08-08-2019 09:43 AM
Thanks for the information. I should do this.
But can we please call it something other than "bullet proofing." There are too many reminders. . . .
GMFL 08-08-2019 10:34 AM
Ok well......
Maybe we could make a list of “bullet points” to come up with a better name?
Gees, Really?
sallye 08-08-2019 11:02 AM
Originally Posted by GMFL (Post 2274679)
Ok well......
Gees, Really?
How about calling it a ruggedized door handle?
Tim A. 08-08-2019 11:12 AM
Well, such a recall would involve a lot of trailers. Our 2002 19' has exactly the same construction of the inside door handle. We never had a problem with it, but, several years ago, I made the same modification GMFL shows. Just a little insurance.
Tim
J-K Georgia 08-08-2019 11:13 AM
Ok well......
Gees, Really?
The term bulletproofing in this usage had nothing to do with what is going on in this world now.
We stop using this terminology, then the next (such as sex describing pins in a connector) etc and soon we will have to come up with a new vocabulary. Some one will always be insulted, inflamed or bothered by what is said.
Silver.Sanctuary 08-08-2019 11:14 AM
I was the victim of the door handle early in my Airstream experience. That was five years ago. I am not smart enough to have made any of the simple fixes which is short sighted but indicative of the procrastination that has hampered a number of my projects.
Good article though, and it is well photographed. Thanks, it should help many folks who otherwise would fall victim to the door!
rwright5 08-08-2019 11:28 AM
GMFL, good implementation. I just did mine this morning. I only had a stainless steel fender washer on hand, so the longest part of the project was machining the middle square hole. (It looks like yours was brass?) The hole in the handle was already drilled a bit oversize for a 10-24 tap, so I only had to tap. I also had plenty of depth for a 1" machine screw.
I have a 2019 23FB and there was no interference with the height of the washer and a Phillips pan head screw.
