-   -   F-250 or F-350 (http://www.airforums.com/forums/f463/f-250-or-f-350-a-198456.html)
dumbclub 07-22-2019 06:41 PM
Originally Posted by graysailor (Post 2267278)
Remember the hight the package the less payload you get.
Obviously, there’s a miscue here, but I can’t figure out what you intended to say for “hight”.
Please give it another shot.
CRH 07-22-2019 07:19 PM
He means higher trim level. A truck with a lot of options will have a lower payload than a stripped down model.
rjmaype 07-22-2019 07:25 PM
Remember:
"You can never have too much truck.
Many times you may find yourself without enough truck.
But you can never have too much truck."
From an old timer who convinced me to buy the F350
davidrrand 07-23-2019 08:14 AM
I agree. If you go diesel get, buy the 350. Many diesel 250/2500s only have a hundred or more pounds of payload than my current 15 Lariat 150 4x4 SCab V8 with 2031 lbs. My previous truck was a ‘99 F350 diesel SCab with 6 speed manual and I loved it. The wife, not so much. Noisy and rough riding but durable and good economy. Don’t make em like that any more but new ones are very nice and twice as capable and twice the $$ too��
JonDNC 07-23-2019 09:06 AM
The new Diesels are much quieter and civilized, we took ours,out last weekend putting on some miles and wife’s comment at the end of the day was more comfortable than our Sierra AT4.
mikeinca 07-23-2019 05:36 PM
Something was brought up briefly in another recent thread and since my questions about it wouldn't have exactly been on topic I didn't want to hijack that discussion. This thread seems like a better place to get some responses from the forum.
To the point, it's been said a few times that "you can't have too much truck" but is that really true? The comment made in the other thread was that a TV that's too stiffly sprung for the task can beat up the trailer resulting in stuff like popped rivets, cabinets flying open while travelling, additional stress on the frame, etc. I know that those kinds of problems can occur with a poorly matched hitch but it seems reasonable that they could also be associated with a poorly matched tow vehicle.
Obviously it depends greatly on individual requirements, but I'm just wondering if the question of F250 versus F350 is really so completely cut and dried. For example, after accounting for all of the fixed payload requirements like tongue weight, hitch, and passengers my 2017 F250 high trim level diesel with max tow has 550 lbs or so of spare payload capacity. Since I typically carry a couple of hundred pounds of gear in the bed of the truck, this leaves me a significant payload margin. Given that all the other attributes of the F250 are more than up to the task of towing my 30' Classic what would be the advantage of a one ton truck in a situation like mine? And isn't it possible that I'm doing my trailer a favor by not towing with a more stiffly sprung TV than I need? Or not.
Thoughts?
turk123 07-24-2019 06:35 AM
This is kind of an experiment, but I am adding an Add-a-leaf to my 2017 ford F-250 Platinum diesel to increase the payload margin. I have no plans to go beyond the "sticker" on the door (2086 lb.) but my thinking is a more stable ride with my 30' Classic.
I have another thread talking more about this and the predicament I am in with payload. That said, the F-350 would have been a better choice for me. The added leaf will allow 1100 lbs. more payload (not legally as the sticker still stands as the limit) and should give me the same stability that the F-350 has. The F-350 essentially is a 250 with an added leaf. My Ford dealer said they would install my third party leaf for under $200. They have no problem with this.
I am also going to add a Suilastic shock for the rear leaf springs. My concern is the more "stiffer" ride and removing some of this stiffness transferred to the trailer. I have also added a rear stabilizer bar (ford) to the 250.
I would say if you are thinking about a 250 diesel, make sure your trim level gives you enough payload. I added an A.R.E. cap (200 lbs.) and a Bedslide (190). Add the propride hitch, trailer, Thule and roof rack, people, big dog, cooler, grill, bikes, tools, rug, and your payload is used up. The 350 gives you a good 1000 lbs. of margin.
Eagle Keeper 07-24-2019 07:10 AM
I was in the same situation. I decided that the 350 is the way to go for the additional payload. There is no real difference in ride quality, I previously owned a 250 so I have experience here. My payload sticker says 3393, it’s a loaded Lariat. I have more options than my friends Platinum! It tows extremely well.
uncle_bob 07-24-2019 08:06 AM
Thoughts?
Hi
Given the way an AS hooks up to the TV, there *is* flex between the two. It's not a 5th wheel. In order for the truck to to crazy stuff *to* the trailer you would need a pretty stiff linkage. With a heavier truck, there is less need for a lot of WD on your hitch. That means a *softer* linkage rather than a stiffer one (at least with most systems).
gypsydad 07-25-2019 02:06 PM
Interested in your ride review when you get this all done...I am looking at the Bilstines on mine, but dealer told me this past week, he wouldn't change till the Rancho's need replacement...he said mine are fine while I was in for service. 60K now on my 2017 F250...Not sure if I will go for the topper or not for our Alaska trip next spring...lots of plus's for having a topper; more room for secure storage and kayaks on top, etc...if I go that route, I likely could also use the extra spring to be safe...:cool:
mikeinca 07-25-2019 03:53 PM
I know your post was directed at turk123 but just thought I'd chime in on the Bilstein series 4600 shocks. My 2017 F250 suspension felt under-controlled on rough roads even when unladen and I had some porpoising when towing; not bad but noticeable. I replaced the front and rear OEM shocks with the Bilsteins even though my truck only had 10K miles on it.
I'm extremely happy with the result. The ride is more composed on rough pavement and on our recent 3000 mile trip after the upgrade I didn't experience porpoising even once. Definitely an upgrade over stock.
turk123 07-25-2019 06:07 PM
I did the same thing. If you want to wait for the Rancho's (actual ford with Rancho's label) to go bad before you install new shocks, you won't wait too long. Mine were gone at 25,000 miles. Bilsteins all around. Billstein now makes a shock for the rear on 2017 and up F-250/350's with no modifications.
Ride is definitely improved. Don't forget the steering damping shock. Mine was leaking and caused a death wobble!!!
gypsydad 07-26-2019 10:45 AM
Tell me more about the "death wobble"! Not sure I knew about that?
gypsydad 07-26-2019 10:47 AM
Thanks for the input! Guess I should order on Amazon and get these going then!:cool:
