-   -   F-250 or F-350 (http://www.airforums.com/forums/f463/f-250-or-f-350-a-198456.html)
olgoat 07-20-2019 04:27 PM
F-250 or F-350
I am in the market for a new Super Duty, upgrading from an F-150. I have driven four or five F-250's and think I have a pretty good feel for the difference in ride quality between the F-150 and F-250. Up to this point I chose not to even look at F-350's because I thought they were only available with an 8' bed. I just learned yesterday that F-350's, although rare, are available with short wheel base. Test drove a short wheel base F-350 today, mixed highway and rough Houston TX city streets, and didn't notice much difference between the F-250 and F-350.
Anyway, does anyone have real world experience moving from an F-250 to an F-350 as a daily driver and how much degradation in ride quality did you see?
The payload improvement is significant about 3,400 pounds for the F-350 vs 2,100 pounds for the F-250 with the equipment we want.
I know it would tow better as a long wheel base, but it will also be a daily driver so I am going to stick with a short wheelbase truck.
Thanks for your input.
pjshier 07-20-2019 05:07 PM
not 250-350, but 150-350
Our increment was F150 to F350 for payload reasons. Mitigated the stiffer-tho-not-deadly ride of the F350 with Rancho adjustable shocks, Sulastic spring hangars in the rear, and airing down the tires when unladen. With the Leer topper, the ride is very acceptable. Not as nice as the F150 Platinum, however.
JonDNC 07-20-2019 06:13 PM
We just bought a F 350 short bed FX4 Platinum. Came from a Sierra AT4. We test drove 250 and 350s back to back and could not tell the ride difference. Same level of trim on both. For the minimal cost delta 350 made sense to us.
Had it a few days and happy so far. Only gotcha is truck is much higher than out Sierra was with a 2” lift. Requires a new longer shank for our Blue Ox.
uraljohn 07-20-2019 06:14 PM
Sulastic Shackles
I second the "Sulastic Shackles". I installed a set on my 2013 E150 XLT van. This van has a 8600LB GVW rating and the rear axle is rated at 5120 LBS. Made for a pretty stiff ride when empty. "Sulastics" really made a big difference.
Anyone that has a F250/350 should take at look at these. Cost was $400.00 and worth it. Took me less than an hour to install in my driveway with jack stands and regular (no air tools) tools.
There are a couple of videos on youtube showing install. Easy stuff.
CRH 07-20-2019 08:06 PM
I have a gas F350 with both snowplow springs and slide in camper certification. Payload is over 4k. I have no complaints about ride either empty or with the AS on the hitch.
CWSWine 07-20-2019 08:19 PM
My Great Great Grandfather came across the USA in months not days in a covered wagon with wood wheels and not much of a suspension system. Today we have gotten so soft that a ride in an air-conditioning Super Duty is too much for us to handle in daily commutes. I'm not exempting myself since I purchased a GMC 3500 because it rode better than F350 and Ram 2500 over other 3/4 ton trucks because of the ride.
uncle_bob 07-21-2019 09:32 AM
Hi
You can get a F-250 Platinum with a payload of a 2,952 pounds on the door sticker. That's with the camper and snow plow packages on it. The next bump up is a 350 for not much more money (less than $2K if I remember correctly). You get another leaf in the rear springs, but not much else. Indeed you *can* add more packages to the 350 from that starting level and take it up quite a bit from there.
Ride wise, that F-250 and the "simple" F-350 didn't really feel all that different to me. A whole lot of things between the two are same / same so it is not the big leap going to a 450 is ride or handling wise.
gypsydad 07-21-2019 10:44 AM
Agree with UB; not much difference in ride, but the extra leaf spring if you need the extra payload, adds a lot more support. Not much difference in price either...guess the question for you is, what are you planning to haul and will you require more than 2200# payload? If so, get the F350 and enjoy! :cool:
We got the KR F250 model with 6.7L diesel, and my only dings are as a daily driver, it is expensive for fuel in some states (MT diesel is cheaper than regular!), oil changes and fuel filter changes are expensive ($105 for oil service and $118 for fuel filter), plus not the easiest to maneuver in parking lots...I get 13-14 mpg at 65mph when towing now, and 17 around town.
While pulling our AS, it is great! Braking, power, and handling our 28' the diesel is great! Make sure to get the step in the tailgate.:flowers:
AlanMcD 07-21-2019 04:17 PM
I went with the F250 gas because it has 3,200 pounds of payload vs. the same truck in an F250 Diesel with only 2,100 pounds, not much more than a F150. Plus the tow capacity on my F250 is fine for my trailer. For that matter most trucks are but most lack in payload. If you want the killer high tow capacity AND payload (~4,000) then the F350 is the way to go.
JonDNC 07-21-2019 05:33 PM
My suggestion when you shop is to compare between 250/350 make sure you compare the exact same spec to understand the ride difference and cost difference. The options can radically influence pricing. I.e. a fully loaded Lariat with additional options can rapidly approach the cost of a Limited.
davidrrand 07-21-2019 10:52 PM
I am planning on upgrading next year with the new model Super Duty from my current F150 Lariat V8. Once the numbers are available on the new 7.3 V8 and I get a feel for fuel economy and any reliability issues, hopefully by next spring, I will choose between the 6.2 and the 7.3 gas engines with 10 spd trans. Several notable upgrade from 2019 to 2020.
Dave
Cirrusaly 07-22-2019 12:21 AM
Made the change from short bed SRW F-250 to short bed SRW F-350 last year, solely because of payload difference. Both diesel. Put 50K on the F-250. Have 21K on the F-350. Both stock; no suspension mods to either.
I detect very little “ride” difference. I like both.
Good luck!
olgoat 07-22-2019 06:08 AM
Good luck!
Good info, thanks.
graysailor 07-22-2019 06:32 AM
I have a Lariat F250 with no complaints. If I were to do it over I would go for the F-350 just because of the greatly improved payload. There is a very small price increase. Remember the hight the package the less payload you get.
