-   2009-2015 Flying Cloud (http://www.airforums.com/forums/f516/)
-   -   Clogged shower drain (http://www.airforums.com/forums/f516/clogged-shower-drain-198432.html)
Arnoldjeff 07-19-2019 09:38 PM
Any ideas for quick fix? I have a 2014 19í flying cloud. Can I try some basic drano? Jackson center says I can get access to trap through a panel underneath, but thatís outside of my skill area...and their first appointment is November! Thanks!
bweybright 07-19-2019 09:51 PM
I would advise against Drano as that introduces Lye, a caustic into the situation. Have you tried a plunger, have you looked for a hair plug in the drain. Have you brought in a garden hose to see if a stronger water flow pushes the plug? Just things to consider before you go to chemicals which can create their own special set of problems.
Another consideration is to go to your local Ace Hardware and get a very think snake designed for sinks to get to the trap?
Good luck!! And trust in your ability to learn new skills with your trailer....the instructions from Jackson Center may help you along that path.
Tim A. 07-19-2019 09:53 PM
Better to use something to get the clog out rather than something which will put the clog in your greywater tank. Most clogs are due to hair accumulations and they can hang up on your drain valve if they make their way to the tank. I found that out the hard way!
Shower clogs are usually in the P-trap area and can be pulled up out of the drain with the proper tool. Try searching in Amazon for "drain snake" and you will find many possibilities. I have been very happy with the Drain Millipede (https://www.amazon.com/FlexiSnake-Dr...gateway&sr=8-3).
Tim
A W Warn 07-19-2019 09:53 PM
Hair buildup in the strainer can be removed with needle nose pliers.
If the strainer is not blocked with hair try a toilet plunger to push the blockageout of the trap.
pcskier 07-20-2019 12:36 AM
https://www.walmart.com/ip/THEWORKS-...e9&athena=true
Acheron2010 07-20-2019 03:21 AM
Baking soda and vinegar. https://crunchybetty.com/clean-your-...-soda-vinegar/
CRH 07-20-2019 06:19 AM
Use one of these:
