-   Awnings (http://www.airforums.com/forums/f442/)
-   -   Tip of Awning Stick (http://www.airforums.com/forums/f442/tip-of-awning-stick-198421.html)
Hans627 07-19-2019 06:46 PM
Tip of Awning Stick
I'm referring to the aluminum rod used to reach the awning lathers and to turn the awning wheel
Somehow I lost the little red plastic tip that goes on the end of the rod. Does anyone have an idea where replacements could be purchased? Or has anyone come up with alternative to the plastic tip?
Thanks!
pcskier 07-19-2019 06:56 PM
I imagine Zip Dee would send you a couple, and then you could glue it on. Not sure why they don't do that.
I just wrapped some electrical tape around it. Then that came off...and I have just left it bare. Just careful to hit the loop, and not touch/scratch the trailer.
bweybright 07-19-2019 06:58 PM
Or you can get a can of liquid electrical tape and dip the end in that multiple times until you get the thickness you desire.
NukeSubSailr 07-19-2019 06:59 PM
I spent a couple of years being careful and putting the red tip back on every time it came off. Then one day I decided mental health was better than a red tip. I threw it away and have not thought about it since.
GMFL 07-19-2019 07:03 PM
https://www.amazon.com/Piece-High-Te.../dp/B018919IDG
pcskier 07-19-2019 07:07 PM
Originally Posted by GMFL (Post 2266441)
Ronnie....no, No, NO. Those aren't red. I'm so disappointed in you. :blink:
GMFL 07-19-2019 07:14 PM
https://www.stockcap.com/store/end-caps.html
I think this is the real one. But you gotta order 1000.:blush:
InsideOut 07-19-2019 07:57 PM
Zip Dee has them. We were at Alumapalooza this year and picked up several replacements.
Shari :flowers:
hotrns 07-20-2019 09:31 AM
Wire Nut
I just glued a wire nut on the end. Worked fine
AtomicNo13 07-20-2019 09:44 AM
You can buy those at almost any hardware store.
drbrick 07-20-2019 09:50 AM
50 Piece 1/4" ID High Temp Silicone Rubber End Caps is $45.00 in Canada on Amazon.ca. Black Electrical tape work find.
mike28 07-20-2019 12:28 PM
They are not necessary. I think they are there in case you accidentally poke yourself in the eye!
Mollysdad 07-20-2019 12:41 PM
Thanks!
You can replace it, but it will fall off again. It takes a beating on the wheel latch. I just left mine off.
However, you can look into "plastic thread protectors" at the big box store.
https://www.homedepot.com/p/8-Red-Ru...2778/204275993
afneill 07-20-2019 01:55 PM
Heat shrink works well. Available in almost all colors. Does not come off easily.
