-   -   Shower head replacement (http://www.airforums.com/forums/f240/shower-head-replacement-198401.html)
TayaraTravel 07-19-2019 11:38 AM
We are thinking about replacing the original shower head on our 2017 Interstate GT with this Camco one:
https://amzn.to/2XTdswg
https://images-na.ssl-images-amazon....AC_SL1500_.jpg
Anybody have a better recommendation?
The goal is a shower head that has a gentler spay (original one tends to lime up and get harsh) and has an off/on switch on the head.
DoubleR 07-19-2019 11:47 AM
Oxygenics is what I see most people get. We have not changed out yet.
SeeMore 07-19-2019 11:51 AM
For $8 for the Camco you can certainly afford to be disappointed.
I changed our shower head to the Oxygenics Body Spa RV eight years ago ($26) and we have been quite satisfied. The design accelerates the water speed giving a sensation closer to an at-home shower without increasing the water consumption rate. It does have an on/off feature which is activated by turning the knurled end of the handle adjacent to the hose connection.
The lime/calcification/debris issue is a function of your water and will affect both the shower heads and sink faucets. You may benefit from using a water filter for both city water connections and tank fills.
AtomicNo13 07-19-2019 01:09 PM
A filter will do nothing for calcium, lime etc.
rmkrum 07-19-2019 02:28 PM
Lime and calcium needs a water softener system at minimum.
TayaraTravel 07-21-2019 03:01 PM
Thanks for the information
BernieMac13 07-21-2019 03:21 PM
We went with two items, a really low-flow, high-pressure shower head and a little valve to completely shut off the water. Boy, has it made a difference in both comfort of our showers and how long our FW tank lasts! And we don't have to shorten our showers as much knowing that it's not wasting water as we lather up! our last rig had an Oxygenics, but we found that we preferred to save even more water than that!
Links:
Shower head: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The shut off valve:
Not as cheap as others, but the most effective model we could find at only 1.5 GPM!
Wayne&Sam 07-21-2019 04:54 PM
Go with the Oxygenics. Lower water usage and higher feeling output.
