-   2011 - 2015 International (http://www.airforums.com/forums/f514/)
-   -   Franklin Chef microwave (http://www.airforums.com/forums/f514/franklin-chef-microwave-197727.html)
aemers22 07-03-2019 12:04 PM
Extended stay at campground in FL. Use Progressive surge protection, twice my pedestal wonít supply current using it, only direct connection to coach. While troubleshooting attempted to use microwave and it cut off. Now canít get it working even with shore power. I flipped the breaker numerous times, couldnít locate GFI switch, nearly ready to purchase replacement since it will cost more to get tech to find/fix problem, thanks for any advise
Mollysdad 07-03-2019 12:41 PM
I'll wager it's not seeing a ground and so the GFI won't pass power.
Does your PI surge protector have a readout? Error code?
LED's code? On mine, if only the green LED is lit, it's showing an open ground.
Correct wiring has both green and blue lit.
The other possibility, is the PI unit is shutting off the power since the voltage is too high or too low. That's only with the EMS units, not the SSP.
Handy tool and cheap! A circuit tester in a adapter.
https://i.imgur.com/TdEUp8a.jpg
