-   -   2019 Classic Toilet running (http://www.airforums.com/forums/f446/2019-classic-toilet-running-197717.html)
ajwbarnard 07-03-2019 07:44 AM
We noticed yesterday when we had the water pump on that the water pump continues to run because the toilet seems to continue to be putting water into bowl in a small trickle. What do you think causes this problem? What part of the system is not working properly? Any suggestions short of taking a 5 hr trip to the dealer? I guess there could be a leak somewhere else that is causing the water pump to run, but I have not seen any other leaking except out of the front of the shower door.
lsbrodsky 07-03-2019 08:47 AM
At the base of the toilet foot lever is a valve that controls the toilet water. If this valve does not seat your toilet will leak into the bowl, with any pressure. You can try disconnecting the water hose at the valve, it uses a hand-tight connection on mine, and squirt some lubricant in there. Then reattach water supply. If that does not work, you must replace the valve, a standard valve at RV places.
Larry
