-   2011 - 2015 International (http://www.airforums.com/forums/f514/)
-   -   2014 International Serenity 23 FB - 22" TV replacement (http://www.airforums.com/forums/f514/2014-international-serenity-23-fb-22-tv-replacement-196870.html)
navpilot 06-13-2019 05:16 PM
First thing why did they install a 22 inch 14 volt tv, which is plugged into 110 socket?? Second whats a good replacement for the forward mount in the bedroom. Its backass wired for the speaker system and has an HDTV antenna hookup with power boost (yea sure, never had much luck with local channels).
Any advice is much appreciated
Doc Foster 06-13-2019 06:27 PM
I assume you mean 12 volt TV. Some 12 volt TV's can be run on 12 volts (12 volt plug), but can ALSO run on 110 volts with standard 110 volt plug. There are several threads about TV mounts. I would first determine which size TV will fit the location and then select the appropriate mount.
navpilot 06-14-2019 08:45 AM
AC converted to DC .. 14 volts
Nope it's 14 volts ...
