-   -   Pump is noisy after winter storage (http://www.airforums.com/forums/f44/pump-is-noisy-after-winter-storage-196690.html)
leedav 06-09-2019 01:04 PM
Hi. 2015 Bambi. The water pump does not sound healthy. Like bad bearings maybe. Assuming it's kaput, is there a quieter replacement that people like?
While I'm here, what are the two stopcocks under the waste tank for?
Thanks!
Rocinante 06-09-2019 01:19 PM
Just a thought: If there is some air in the lines, sometimes our water pump is noisier than usual.
A pair of brass stopcocks under the waste tank could be the low point drains for your water lines. A single white plastic stopcock could be the low point drain for your fresh water tank.
leedav 06-09-2019 01:28 PM
Thanks. Those are under the fresh water tank. But I think those are under the hot maybe.
Crackerman 06-09-2019 08:58 PM
You have air in lines. Fill tank, turn pump on, open all spigots and flush toilets for 30 seconds or more.
As you close each faucet, it will get quieter
jimfa440 06-10-2019 10:54 AM
The pump could possibly have been knocked against something or something lying against the pump or one of the rubber feet could be missing. Either condition could cause an unpleasant noise.
OTRA15 06-10-2019 11:00 AM
Echoing "air in lines" comments. Run hot and cold water from all lines [incl. exterior shower, kitchen sink spray head, and toilet] until no air is left in any line. Sometimes you have to go around the circle again to make sure of this.
