-   1984 - 1989 Sovereign (http://www.airforums.com/forums/f210/)
-   -   Curbside vibration 85 Sovereign 34' (http://www.airforums.com/forums/f210/curbside-vibration-85-sovereign-34-a-195615.html)
krohnjs 05-13-2019 10:29 AM
Items on no-slip on center dinette end up on floor while towing. Doing this full time 20+ yrs and problem just began (the no-slip is fairly new). Nothing in other locations affected. Have had suggestions of bad tire, unbalanced wheel, bad shocks. Anyone had a similar problem that might suggest which if any of these suggestions might be the culprit?
n2916s 05-13-2019 10:36 AM
I'd go with tire or wheel. Might be as simple as you threw a balancing weight, could be a belt separating... Don't think one bad shock would be that dramatic.
Threw a weight on my trailer years ago and had similar symptoms. Went to Centramatics and it solved the problem
