-   -   Mounting ham antenna on Airstream trailer (http://www.airforums.com/forums/f142/mounting-ham-antenna-on-airstream-trailer-19497.html)
Airstream25 12-04-2005 01:15 PM
Ham radios can be a good compliment to cell phones. Cell phones are great in the city and along Interstate Highways but in the rural part of sparsely populated western states, service can not be depended upon.
VHF and UHF ham radio repeaters are frequently located on mountain tops where they provide service to much of the rural areas.
Now the question, how to mount the antenna on the trailer?
The standard 5/8 wave mag mount 2 meter antenna used on the steel roof of a truck wont adhere on the aluminum trailer. A bolt or screw on mount could work but would be in the way when trying to park the trailer in the shed. The trailer being so tall, removing the antenna is not convenient.
Suggestions??
azflycaster 12-04-2005 03:34 PM
If you have a crank up television antenna, you could mount it on that.
BTW, I hope you did not offend Porkey Pig with the tittle of this thread! pig:
TomW 12-04-2005 04:29 PM
Originally Posted by Airstream25
... Now the question, how to mount the antenna on the trailer? ... Suggestions??
Here's how my CB antenna is mounted.
Tom
Airstream25 12-04-2005 06:32 PM
Tom,
I checked the picture of the CB antenna on your web page. Thanks.
n7bdl 12-05-2005 08:27 AM
I installed an NMO mount in the refer vent cover and fished the coax down into the refer compartment, then into the trailer. It can be done (barely) without removing the cover. I use this for an external cell phone antenna. I will probably add anothe NMO for a ham or CB antenna. I use the NMO mount for almost all of my antennas, so they will interchange.
J Goertzen 01-14-2006 01:44 PM
What Is A Nmo Mount? Thanks, Jim Kb6oin
n7bdl 01-15-2006 06:23 PM
The NMO (New model Motorola) is a very common VHF/UHF antenna mount. I have CB, cell phone, and ham antennas that use it. You can find it with or without cable in many different configurations at Ham or CB stores. The roof mount, which I used on the Airstream refer vent, requires a 3/4 " hole.
SARGE/AF 09-15-2011 08:10 AM
Radio Antenna Install
Originally Posted by Airstream25 (Post 192429)
Ham radios can be a good compliment to cell phones. Cell phones are great in the city and along Interstate Highways but in the rural part of sparsely populated western states, service can not be depended upon. VHF and UHF ham radio repeaters are frequently located on mountain tops where they provide service to much of the rural areas. Now the question, how to mount the antenna on the trailer? The standard 5/8 wave mag mount 2 meter antenna used on the steel roof of a truck wont adhere on the aluminum trailer. A bolt or screw on mount could work but would be in the way when trying to park the trailer in the shed. The trailer being so tall, removing the antenna is not convenient. Suggestions??
I have a 3 stage extendable steel pole for antennas that is mounted on the hitch and is removable, It is on a bracket that allows me to lower it, extend pole then put it back up. I disconnect it during travel even thow in its retracted state it is no taller than the AC on the trailer, I just dont like having it there full time only when I plan on using it.
You can find this pole available from most ham radio stores, mine was given to me and came from HRO.
Sarge KG4KWP
RickDavis 09-15-2011 08:26 AM
For VHF/UHF I would suggest the NMO mounts permanently installed and 1/4 wave antennas which would only be 19 inches at 2 meters,and are flexible enough to get out of the way when going into the garage or whatever.
Based on many years on an antenna test range I can assure you that you will see no difference in performance with the 1/4 wave as compared to the larger 5/8.
On low frequencies we have pipes U bolted to the back bumper on each side.
One has a screwdriver antenna. We remove the whip when traveling. The other can be used for a Hustler 5 BTV when we are parked for longer periods.
The 5 BTV does provide a noticeable improvement on 75 meters where I do most my operating, less so on 40 and probably little or no improvement on 20 meters and up when compared to the screwdriver
mefly2 05-22-2012 11:18 PM
How about a leighweight aluminum pneumatic mast assached to the tonge / a-frame ...
Bruce B 05-23-2012 04:48 AM
For all things "mobile ham" I begin on K0BG's website. He (Alan) is the master!
KBG.COM
I prefer my ham radio in the truck or if there is internet available I can remote my entire home HF station. Now that is a blast!!!!
Bruce
ole81 06-29-2012 09:11 PM
Hi to all HAMS...
Unfortunately, as age increases, one has to start winding down on activities. Unfortuantely, Packards, Planes, and PCs, and AirStreams have been in my life longer than radio, so I am reluctantly starting to downsize some of my equipment.
I have an antenna that was mounted on the back of our 1981 Airstream. It was specifically designed for the Airstream many years ago....in fact, an article was published on its specs. It is mounted on the back bumper and can be lifted with a bar.
I am not home at the moment to give particulars, but if there is a HAM who would be interested, I will forward details.
We are located 25 west of Houston....
K5RPS
SARGE/AF 07-14-2012 05:31 AM
Originally Posted by ole81 (Post 1167608)
Hi to all HAMS...
K5RPS
I would be but getting it from Houston to TN maybe a problem, I would be interested in the particulars of maybe remaking another one for myself.
Sarge
ole81 07-24-2012 05:31 PM
Sorry for the delay in supplying more information about the antenna mount. I had misplaced the info that I have.
There was a 3 page article in some book (maybe an antenna book?!?!)...chapter 15, p6-8. The article talks about a Deluxe RV 5 -Band Antenna....and references information by Charles Schecter, W8UCG, which was published in QST Oct, 1980.
The design was intended for a31' Airstream....the year may be irrelevant.
I don't feel it would be appropriate to try to post the 3 pages on the forum, but if any HAM would like a copy of what I have, send me a private msg.
