-   -   What it's this and is it useful? (http://www.airforums.com/forums/f464/what-its-this-and-is-it-useful-194711.html)
wandered 04-20-2019 01:22 PM
It's a 1" ball mounted on the side of the frame. I'm guessing it was added by the previous owners and used as anti sway at some point? I'm restoring the front and plan on removing it unless it has some value that I'm unaware of...Attachment 338641
wandered 04-20-2019 01:24 PM
Auto correct is my grammar nemesis.
"What IS this and is it useful?"
Hiwheel Joe 04-20-2019 01:47 PM
Yes. Old friction sway control. If not using one remove it. I removed mine and just put a dab of sealer on the screws and put them back in the holes and painted over.
wandered 04-20-2019 01:57 PM
Excellent - will do and thanks!
AlinCal 04-20-2019 02:44 PM
read this :)
http://www.airforums.com/forums/f464...le-193779.html
wandered 04-20-2019 02:52 PM
Originally Posted by AlinCal (Post 2233111)
Great thread; I will definitely save -- thanks!
jimfa440 04-21-2019 10:52 AM
I had one and changed hitches. I just guessed that 6 holes drilled that close together could cause weakness. Get it? guessed. So I took plate steel the same dimensions of the sway control and bolted it in place and painted it. It looks fine and it remains strong.
cazual6 04-25-2019 11:51 PM
I concur
