-   Plumbing - Systems & Fixtures (http://www.airforums.com/forums/f163/)
-   -   Grey water tank filling from city water (http://www.airforums.com/forums/f163/grey-water-tank-filling-from-city-water-192890.html)
bearded19711 03-06-2019 07:44 AM
Iíve got a 2016 22 Sport that Iíve had for a couple of years, but still consider myself a newbie because I havenít had any problems until now.
Weíre on our first trip of the year, just starting a 6 week trip out west but did not de-winterize until we got here in the FL panhandle. Within a half day after hooking up to city water here at a state park, the grey water tank filled up, and not by us using water in sinks or shower, we had used very little at that point. The digital level readout (always unreliable) read zero but the shower drain started gurgling when we used a sink, and the sink water didnít drain. I went out and drained the black tank first and got what seemed like the right amount out of it. Then I drained the grey tank and it flowed forever. Sinks started draining immediately. This whole scenario happened again within a day.
Since then I filled my water tank and disconnected from city water. No problem with this scenario.
Question: How is my grey tank filling from city water without using sinks or shower?
How can I fix it?
Sorry for the long post. I tried searching the forum but am limited to my cell phone here at the park.
Thanks for any help!!
daleyocum 03-06-2019 08:19 AM
Quite the mystery! Are you absolutely sure the grey tank was empty when you hooked up to city water and wasnít overlooked in the winterization process?
OTRA15 03-06-2019 09:12 AM
Originally Posted by daleyocum (Post 2217045)
Quite the mystery! Are you absolutely sure the grey tank was empty when you hooked up to city water and wasn’t overlooked in the winterization process?
The OP said it happened again, after draining the grey water tank.
Originally Posted by bearded19711 (Post 2217035)
. . . This whole scenario happened again within a day.
bearded -- when you are hooked up to city water, have you looked carefully for leaky faucets, especially during the night? Try turning off city water at the hose bib, except when you need it. Use the water tank for flushing during the night, etc.. In other words, try to adjust some of the variables. Chances are good you will get a handle on this IMO.
Good luck,
Peter
bearded19711 03-06-2019 09:39 AM
Thanks for the responses! Still puzzled. Got a call in to Colonial Airstream where I bought it. The first guy I talked to was puzzled too! A more experienced person is supposed to call back. Keep your thoughts and guesses coming! Iíll let you know what the solution was when we solve it!
OTRA15 03-06-2019 03:19 PM
Originally Posted by bearded19711 (Post 2217076)
Thanks for the responses! Still puzzled. Got a call in to Colonial Airstream where I bought it. The first guy I talked to was puzzled too! A more experienced person is supposed to call back. Keep your thoughts and guesses coming! I’ll let you know what the solution was when we solve it!
Are you sleeping in the trailer tonight? Try the suggestions in Post #3 . . . no need to wait for an "expert" to comment. You can become the expert for your Airstream!
Peter
AlinCal 03-06-2019 03:22 PM
The only connection between city water and the grey tank is thru the faucet, if its not running/dripping it cant happen.
This would be a serious health risk "if" someone did some creative plumbing to make it happen, not from what ends up in the grey tank but what could end up in the city supply from a cross connection.
As Peter is saying you need to verify with a few tests.
daleyocum 03-07-2019 12:25 AM
Just had a thought. Since the trailer just came out of winterization could there be a bypass valve still open now that wasnít open before? Maybe even a valve that wasnít plumbed correctly but didnít show up previously because it was shut.
jimfa440 03-07-2019 10:31 AM
Check your city water pressure regulator. If it is set high or not functioning, you could have way too much water pressure, not available from your fresh water tank pump.
An easy way would be to install a water pressure regulator at the spigot.
WhereStream 03-07-2019 11:45 AM
There's another person on Airforums seeking a explanation to this same problem.
smithcreek 03-07-2019 12:11 PM
This is a drawing of typical AS plumbing. Two pipes go into the gray tank from the various drains and there is one vent pipe. All these pipes are large diameter pvc.
I don't see any possible way to accidentally tie in the 1/2" fresh water pex piping to a drain pipes. The only reasonable way for water to enter the gray tank is through one of the drains. I'm going with leaking faucet.
Lucy Goosy 03-07-2019 01:00 PM
Gray water filling
I had the same problem last year. I accidentally used a different, smaller white hose to connect my fresh water. When i saw the dripping and filling of the gray water tank I added a water pressure valve at the source and that ended the over flow. Weird but true...
Good luck
AlinCal 03-07-2019 06:29 PM
Good luck
When you "saw the dripping and filling the grey water tank" are you saying the faucet was dripping into the drain?
Personaly I would never leave my trailer hooked up to city water 24 x 7, especially with no regulator and no sewer connection.
Lucy Goosy 03-08-2019 10:02 AM
No there was no water dripping from faucet. I think the smaller hose created more pressure. I went back to the hose that came with the AS and put a regulator on it.
Al and Missy 03-08-2019 11:08 AM
A hose cannot create more pressure. In fact, a smaller hose will induce a pressure drop with flow. When there is no flow, the pressure will be the same regardless of the hose diameter. It's physics.
If it is fixed, it is fixed because you added a regulator.
Al
