-   LP Gas, Piping, Tanks & Regulators (http://www.airforums.com/forums/f287/)
-   -   2 new aluminum 20# lp tanks (http://www.airforums.com/forums/f287/2-new-aluminum-20-lp-tanks-192767.html)
Mx468 03-03-2019 08:41 AM
Hi I have an opportunity to buy 2 never used 20# aluminum worthington lp tanks for $125 for both, is this a good deal? I plan on using them on my 1972, 23 ft Safari. I currently have 30# steel tanks on my airstream. How long do the 20 lb tanks usually last when boondocking? I know a loaded question and different answers for different scenarios. I'm thinking about 3 days of boondocking, using stove, oven, shower and fridge.
Adventure.AS 03-03-2019 09:07 AM
How long does your 30# tank last? A 20# tank will last about 2/3 as long.
daleyocum 03-03-2019 09:14 AM
Check the dates on the, as well. They need to be recertified every 12 years. This thread might help. http://www.airforums.com/forums/f287...on-115746.html
Itís a good deal to answer your first question if they are fairly current.
kenfconnor 03-03-2019 09:31 AM
I paid less than $10 recently to have mine recertified at the local propane dealer. $125 for 2 tanks is a good price.
kidjedi 03-03-2019 09:31 AM
Are your tanks bad? Just wondering why you'd switch from 30's to 20's. Perhaps because they're aluminum and not steel (which is a valid consideration). That's a good price for two aluminum tanks (if they're in good condition), but I personally prefer larger tanks.
kidjedi 03-03-2019 09:33 AM
Actually, every state has its own rules. here in Colorado it's 10 years after manufacture and every *five* years thereafter. But it's only around $10/tank to certify.
AlinCal 03-03-2019 09:45 AM
Carrying two 30# tanks for OUR typical 7-10 day summer camping trips is overkill, Now change that to winter time and you are glad they are there.
I used to wonder why AS trailers had so much propane capacity when you have such limited water, waste water and battery capacity, that was until we camped in cold weather and had to run the furnace.
Mx468 03-03-2019 10:06 AM
The tanks are brand new never been used. Yes they’re aluminum and the 30’s I have now are steel. I plan on polishing the airstream this spring along with tanks. We only use the airstream during summer months. Thanks.
kidjedi 03-03-2019 11:51 AM
It's not just about *one trip* though. I would hate to have to fill my tanks before *every* adventure. ;)
AlinCal 03-03-2019 12:07 PM
It's not a one size fits all that's for sure, but carrying a month worth of gas seams more than enough for us.
AirMiles 03-03-2019 12:52 PM
I use 20# propane exchange tanks on my solar powered Airstream. I primarily dry camp and use propane for refrigeration, heat, hot water, cooking, and occasional AC and microwave use with my propane fueled generator. I believe a 20# tank lasts me for 10 to 14 days. I prefer to just stop at a Walmart for a $15 exchange tank rather than find a place to refill the tanks. Occasionally, I get the exchange tanks refilled if its convenient and fairly priced.
PKI 03-03-2019 01:37 PM
Sounds like a good deal and you can always transition back to the steel tanks if you are not happy with the 20's. Polished aluminum will look great. However, the aluminum tanks listed by on-line providers suggest that scratches and marks should be expected. Polishing may be a big job and some scratches may not buff out. Pat
Mx468 03-03-2019 02:58 PM
Yeah the ones I just got were still in the box never used no scratches. I Found them on Facebook marketplace. I think the manufactured dates on them are 2016.
suncoasteng 03-04-2019 06:36 PM
Yes, but how old are the aluminum tanks? Remember that all tanks now require a OPD, and some LP stations will no longer re-certify a tank that does not have one. In fact, with new DOT regs, many LP Gas vendors would rather sell you a new tank than run the risk of re-certifying your old tank.
Personally, I would just buy two new 30 lb cylinders and wax them with car polish wax once a year, you dont even need to buff the wax!
OPD Cylinder Valves. OPD stands for "overfilling prevention device" or "overfill protection device" and is required on all 4 to 40 pound DOT cylinders in vapor service. The OPD valve is simply a protective device that, as the name implies, prevents overfilling of a propane cylinder.
Here is latest info on DOT regs for LP tanks
http://www.propane101.com/consumerpropanecylinders.htm
