-   -   replacement a/c shroud? roof vents? (http://www.airforums.com/forums/f427/replacement-a-c-shroud-roof-vents-1927.html)
Dave Cole 10-02-2002 01:43 AM
my 1969 25' tradewind (at least i think so: 025t9j166) came all original, though left to the elements for way too long. the plastic shroud around the a/c is mostly gone due to cracking and falling off, and the other two plastic roof vents are also on their way out. even the two vent stacks are really chaulky, and look like a stiff breeze would do them in. can i get replacements for these? They dont have to be exactly like the originals, but i don;t want them to be too out of sync visually.
53flyingcloud 10-02-2002 02:23 AM
Replacements
Dave, check with Andy of InlandRV.(He has over 30 yrs experiences with A/S)
ciao
Inland RV Center, In 10-02-2002 07:13 PM
AC Shrouds
We will have fiberglass AC shrouds for 1964 to 1969 units and for the 1970 to 1972 units in about a week.
inlandrv.com
airstreamparts.com
JPAIRSTREAM 10-02-2002 07:55 PM
025t9j166
O=Overlander
25=25'
T=Twinbeds
J=Jackson Center
166= numerical serial number
smily 10-03-2002 06:55 AM
Serial number
JPAIRSTREAM,
I did not know that AS made a 25 foot Overlander.
Is this the correct interpretation of the serial number?
You can verify at the AS web site.
What year is the AS?
Smily
Dave Cole 10-03-2002 09:20 AM
0=land yaght
definately a tradewind
i think the o means landyaght trim pkg (which i have)
supposidly, by '69 they had switched to the L for the landyaght designation--but i guess ohio hadn't heard yet.;)
JPAIRSTREAM 10-03-2002 12:18 PM
Originally posted by JPAIRSTREAM
025t9j166
O=Overlander
25=25'
T=Twinbeds
J=Jackson Center
9= 1969
O= Typically stands for Overlander but your right that year it might would have been a
dry weight = 4525
tongue is 490 TWIN/Double modelTrade Wind /deluxe model LY
Stougard 10-03-2002 02:06 PM
Andy,
Do you plan to get any A/C shrouds for a 73? Mine has been broken up by low hanging branches. Also, is it normal to have a big square hole at the top center of the shroud or is there something missing from mine? Obviously since there are no other vent slots this hole must be where the air intake is. Seems alot of leaves and other junk gets in there. The privious owner made a screen for the hole but it disintegrated.
Larry
krazeekalvin 12-05-2009 07:47 PM
I replaced my A/C shroud that I bought from Inland RV when they where on sale. Very simple to install.
overlander63 12-05-2009 08:00 PM
After 7 years, I think the original poster has probably solved his shroud issue by now.
