-   Jacks, Stabilizers, Lifting and Leveling (http://www.airforums.com/forums/f457/)
-   -   Jack Point "Missing"; I Used Axle...... (http://www.airforums.com/forums/f457/jack-point-missing-i-used-axle-192310.html)
Rounder44 02-17-2019 04:27 PM
Howdy,
Well my curbside axle label and square point are there but not my street side! Had a flat on street side and no indication of where to jack and surmising I could easily punch through if not in the right place so.... I opted to use the axle.
I put the jack on the square axle as far out board as I could..
Axle lift makes most sense to me but since actual jack points indicated (or not in my case) I'm wondering what the deal is.....
So for future reference could this be cleared up for me?
Rounder44
AlinCal 02-17-2019 05:15 PM
There will never be anything unanimous on Air forums but I routinely jack our trailer under the axle at the frame mounting point.
A W Warn 02-17-2019 05:28 PM
Originally Posted by Rounder44 (Post 2210786)
<<snip>>
<<snip>>
It is better to place the jack on the axle mounting bracket right beneath the trailer frame, or place the jack beneath the reinforcing plate that is welded to the trailer frame.
Jacking on the axle tube can damage it.
Al and Missy 02-17-2019 05:42 PM
My roadside label came off. On my trailer it was a square piece of diamondplate riveted to the trailer. I use the rivet hole as a marker. Previous jack pads have deformed the the belly pan making it easy to see the frame rails as well.
Al
AlinCal 02-17-2019 05:45 PM
The axles structural steel beam is the thickest piece of steel on the entire trailer. Only damage will be scratched paint.
A W Warn 02-18-2019 06:09 AM
this is copied and pasted from Dexter's website:
"Dexter recommends that you do not jack up the trailer on the suspension components because there is always the potential for damage. Bent hangers, leaf springs, or axle tubes can cause bad axle alignment with bad tire wear resulting. Also, many trailer builders do not use Dexter hangers and we have no idea how strong these hangers may or may not be. Therefore, we take the conservative approach and recommend jacking up only on the trailer frame."
AlinCal 02-18-2019 08:14 AM
That is obviously for their leaf spring suspension system and does not apply,
there are no hangers in the Torflex system.
If you go to the Torflex lit. you will see they call the center beam the "main structural member" and that the axle can be used as a load carrying cross member.
https://www.dexteraxle.com/docs/defa...).pdf?sfvrsn=4
dlkershaw 02-18-2019 08:42 AM
Jack point 22fb
4 Attachment(s)
Good Morning Rounder, I had the same issue with my 22fb, same location. I traveled to Colonial and had the tech show me where the street side jack point was.
I marked the jack point with tape. The jack point is located on a straight line opposite the curb side. Best of luck, We traveled 7000 miles from NJ to Montana, SD, ND and Wyoming. Great trip. Attachment 333867
Attachment 333868
Attachment 333869
Photos: Number 1 : Located between Stabilizer and Gray tank
Photo #2 : About 11 inches from the curved outer edge of the street side.
Photo #3 Just different perspective of the seam.
OTRA15 02-18-2019 09:07 AM
What does your owner's manual say?
JCWDCW 02-18-2019 09:20 AM
I now use a stepped block to raise the flat wheel since I have dual axles, but I have routinely jacked using the axle frame that Dexter axles are mounted on. If this frame can handle impact loads from pot holes and curbs, it can certainly handle a jack. I'm sure Dexter don't want you to use the axle mounting frame because it removes any liability for misunderstanding as to how to do it.
BTW once the wheel is clear of the ground you should be using a Jack Stand to support the weight. I usually put under the axle frame in the middle between the wheels, and then ease the jack back down onto it if I'm leaving the trailer without the wheel for any length of time.
JCW
franklyfrank 02-18-2019 11:48 AM
Howdy,
Rounder44
You are over thinking it.
I only owned twin axle trailers and always place the Jack under the frame where schockabsorber is mounted. I Jack up mine frequently to check the tires and brakes . No issues whatsoever.
Rounder44 02-18-2019 12:03 PM
Hi,
Owners manual says use jack point and has a photo of a label saying "JACK" with an arrow pointing to a square plate jack point.
Both are missing on my coach..
R44
Rounder44 02-18-2019 12:06 PM
JCW
Begs the next question... where would one place a jack stand for extended service?
I'd have to say obviously the axle....
Since the "jack point" in ~ 3 square inches that doesn't leave room to add supplementary support.
R44
A W Warn 02-18-2019 06:24 PM
The link you provided does not mention jacking.
This is where I found the information I posted above, advising to not place a jack under the "axle tube". Scroll down to find it.
http://www.dexterpartsonline.com/page/398255222
An axle tube is an axle tube, regardless of axle type.
Yes, the center beam, or axle tube, or whatever you want to call it is a structural member. But, bending it will change alignment of the wheels/tires on any kind of axle. Jacking on the axle tube might damage it.
The axle mounting brackets is the point that carries the axle load. I agree that the bracket where it is attached to the frame reinforcing plate (frame carrying the load) at the end of the axle tube is a good place to jack to lift the trailer (that is what I posted above)
If the jack is place on the square tube to lift multiple tires of a tandem or triple axle off of the ground, then that point will be carrying more than the design load of one side (half) of one axle. Whether or not the tube will deform under this load I do not know, but I doubt it. I do not want to find out the hard way.
The trailer frame is reinforced with a plate that carries the load of all of the axles. That plate is where I place a jack to lift all tires on one side of the trailer at the same time.
When it is necessary to use jack stands to support the whole trailer at once, those jack point plates that are riveted to the belly is where I suppose it is proper to place those jack stands. Therefore when placing the jack stands, it is impossible to place the jack to lift the trailer and the jack stand at the same location at the same time. That is why I think it is proper to use the frame reinforcing plate where the axles are attached for lifting one side of the trailer.
