-   Classic Motorhomes (http://www.airforums.com/forums/f311/)
-   -   Suggestions for Weep Hole Covers (http://www.airforums.com/forums/f311/suggestions-for-weep-hole-covers-19115.html)
Chaplain Kent 11-10-2005 09:50 PM
I need suggestions for weep hole covers. We have the $9.00 plastic version available from Inland and other sources. We also have the possibility of designing a new weep hole cover and having that made. I do have a party interested in taking on this task if they can make it economically feasible for them. What I need is suggestions as to what it should look like and be made out of. I personally do not like the current weep hole covers. I can break new ones by simply washing the windows and the older ones get very brittle.
How about making them out of metal? Extruded aluminum? Lightweight aluminum so they are flexible?
Give me your suggestions, please.
ALANSD 11-11-2005 07:42 AM
seems to me aluminum would be great if it is feasible and affordable. The idea is of course only to prevent insects coming in and give the window track an outlet for drainage. Is there not something available from other brands that would fit and do the job? We might have to check that out. i will do some research also, as I am not happy with the way the newer replacements have held up, they fade, crack and age way too soon.
saw this posted on a general RV forum funny huh;
""If so, I'm not aware of any covers for them. We've owned several rigs over the years (travel trailers, Class C, and Class A), and none of them came with covers on the weep holes. In fact, I've never seen a rig that had covers on the weep holes. "
what rigs has that guy seen?
ALANSD 11-11-2005 08:05 AM
what about this idea;
silver buffalo 11-21-2005 03:46 PM
Alan,
I would be interested if you come up with something. About half the covers on my 310 are missing/broken/cracked/faded. The picture you have of a possible substitute, is it aluminum?
ALANSD 11-25-2005 05:02 PM
not sure what its made out of, did a search and found it, I might order one after I recheck the size.
rvlover 11-25-2005 07:54 PM
Good luck on your search...I will join you since my weep hole covers are gone, gone, gone....Joe
Chaplain Kent 11-26-2005 04:23 PM
This is a perplexing problem. I asked for ideas and only got a bunch of PM's from people who also need weep hole covers. What I really need is ideas so I can pass them on and have them made. There is someone who is interested in helping us out but the cost to make a mold for what we have is prohibitive. Let's put our collective minds together and come up with an idea for weep hole covers which can be made cost effectively and be serviceable to us.
ALANSD 11-26-2005 05:10 PM
What about using a current model as template and creating one the same dimensions using polymer? Not sure how you go about this, but seems like that material would be good for this app.
SwanMfg 01-20-2006 03:57 PM
Alan-
The ones you sent here look like either Nitrile or maybe PFTE.
The ones we're sending you are made from rigid polyurethane. It tends to withstand UV and abuse better than the other materials. You'll have to let me know how these hold-up in comparison to your experience with the others. I've been thinking that these could be reengineered somewhat...they're rather thin. It looks to me like they could be about 50% thicker without affecting performance. I also think the tabs could be thicker, but am unsure about how much space is available to play with.
After reading through some of the forums, though, the solution may be to make these from flexible poly instead. This product comes in a variety of hardnesses & would bend rather than snap if smacked with something. The downside is that flex poly is more expensive/gallon than rigid poly. However, if you get 5-10 times the use out of the part, then the price differential would be well worth it.
Chaplain Kent 01-21-2006 08:28 AM
Steve at Vintage Trailer Supply has the weep hole covers in stock now for $6.95 and $5.95 for the small. I have just received my order and they are perfect. They are almost a perfect match for what we had as original equipment and you can not beat the cost.
http://www.vintagetrailersupply.com/
SwanMfg 01-21-2006 09:36 AM
What do you think about the flexible poly idea? It's pretty tough stuff & can take getting hit with a hammer without breaking. It can be made to look exactly like the original parts, with the only real difference being that they're made from synthetic rubber rather than hard plastic.
I'm trying to fully understand your needs on these in order to make a superior product. I won't use the forum as an advertising media, so I'll leave it to Alan to give you the skinny on the pricing we discussed for these...but I think you'll be pleased.
ALANSD 01-22-2006 08:44 AM
I spoke with Steve yesterday and he is sending me samples of the weep hole covers for me to check out. Hopefully his material will be more durable and UV resistant than the past ones I have used. We spoke about his ideas to improve the front window smaller covers, and I am anxious to see how they will fit, slightly thickened from the originals.
I will keep you all posted.
97sx 05-15-2011 10:55 PM
Is there an affordable option to these today? I would like to replace them all. Inland has them but the total bill would be over $300 to replace them.
Keyair 05-16-2011 11:36 AM
I am working on an Idea for some that will look great, and be long lasting...
Will post something soon..
