-   -   Sirius radio (http://www.airforums.com/forums/f44/sirius-radio-191111.html)
Mahc 01-12-2019 01:10 PM
Sirius radio
I was having to restart the Fusion/Garmin radio in order to change the channel. I found out that the module for the Sirius portion overheats and freezes the radio. I also had burned out USB ports which I think are from the same module overheating. I spoke with Garmin and even though it is not their issue, they are trying to create a fix that would automatically restart the radio when it overheats. This is s design flaw because the module should probably be in a different space with more ventilation. If Garmin canít come up with a solution I will need to go back to Airstream. When I initially took it in to address the issue, Airstream had no idea what was wrong. Has anyone else had this issue?
