-   Computers, Internet & Satellite (http://www.airforums.com/forums/f451/)
-   -   Ext to Int coax ok for Dish sat? (http://www.airforums.com/forums/f451/ext-to-int-coax-ok-for-dish-sat-183241.html)
marter 06-21-2018 01:37 PM
I know this has been discussed many times, but I haven't seen a consistent answer.
Is the coax from the external cable jack to the inside coax jumper plate in my 2008 International 19' sufficient to use a Dish Playmaker and Wally if I remove the jumper and connect the Wally to the Sat In connector (and run HDMI to the TV) and leave the antenna booster turned off?
Mike
LBOskiBear 06-25-2018 09:55 PM
I might be able to answer your question after this weekend.
I just acquired a Tailgater and Wally - am planning on doing this.
We both 2008 models - not sure if the wiring is the same. According to my owner's manual, I connect the satellite to the outside coaxial input. That brings it into the trailer.
I connect one end of the coaxial from the inside faceplate to my Wally receiver's input. That's supposed to create essentially a direct connection from the satellite to my Wally.
What's different is that the Wally doesn't have a coaxial output. According to my manual, if I had a coaxial output from the Wally, that would go into the other coaxial in the faceplate and the signal would be sent to both TVs.
However, since I don't have that, I guess I just run an HDMI directly from the Wally to my TV.
The Ice Man 06-25-2018 10:48 PM
We have the exact same set-up and that's the way we do it. It works like a charm.
marter 06-26-2018 06:21 PM
Thanks for the replies.
@LBO, I don't think would work, based on what I've read here. The connection between the dish and the wally has to be direct, no delays or splitters. My TV has an HDMI connection and it's right by the splitter.
@Ice, thanks for the info. My cable and connections are good, I was worried that the coax might not be up to spec as to what the signal needed to be. Glad to hear it works.
Happy trails,
Mike
The Ice Man 06-27-2018 09:48 AM
The Walley needs to send a signal back to the Playmaker and a splitter interferes with that. Diodes, maybe?
At any rate, Dish to external AS male connection; at the plate, coax from the Satellite In to the Walley; HDMI from the Walley to the TV. It's worked like a charm for us for the last two years.
marter 06-28-2018 07:36 PM
Good to know. That's my plan.
Any opinion on portable dishes? Not sure I need the X2's dual arc, since we will probably never travel in the northeast or Florida. Leaning toward the extra cost of the Tailgater instead of the Playmaker. Any opinion?
Mike
Al and Missy 06-28-2018 08:49 PM
The connector on the outside of the trailer and the one on the plate on the inside are two ends of one cable. I used mine for DirecTV, but I don't know why Dish would be different.
The HDMI connectors and cables are completely different from the coax AFAIK.
Al
marter 06-28-2018 10:21 PM
Thanks for the reply. I assumed that was a direct connection before it was rerouted theough the plate to the DVD. My concern was whether the coax was sufficient for the current Wally receiver. Figured it was, but before spending the cash I wanted to hear from others that had it working.
Thanks again,
Mike
The Ice Man 06-28-2018 10:40 PM
Mike:
The Playmaker works well for us, BUT things get awfully flat east of Denver and from that little crest just east of DEN I think you can see Chicago. Never been east of the Mississippi, so I wouldn't know if it's worth it or not.
:D
marter 06-29-2018 07:09 AM
Originally Posted by The Ice Man (Post 2121579)
Mike:
Flat? I live in Nebraska. :D I know flat.
Looks like the X2 is about twice as big as the Plamaker or Tailgater, so that's not an attractive option. I talked to a Dish rep and she really pushed the Tailgater over the Playmaker. Trying to see why.
Thanks again,
Mike
LBOskiBear 06-29-2018 10:44 AM
Thanks again,
Mike
Mine is going to be tested this weekend, so will report back on the outcome.
I had the exact same conversation - the Dish rep strongly suggested I avoid the Playmaker and go with the Tailgater. He said that people were less than impressed with the Playmaker.
The cost difference was negligible and the Tailgater was pretty, so I went with it.
TG Twinkie 06-29-2018 11:47 AM
I have a Playmaker. It works great.
Sent from my VS500 using Airstream Forums mobile app
marter 06-29-2018 12:00 PM
Looking forward to your results. Hope it works for you.
Mike
marter 06-29-2018 12:02 PM
Thanks TG. Pretty good price at $309 here locally for the bundle with the Wally.
Happy trails,
Mike
