-   Base Camp (http://www.airforums.com/forums/f404/)
-   -   Basecamp (http://www.airforums.com/forums/f404/basecamp-182596.html)
Goodgercan 06-06-2018 01:38 PM
Basecamp
I have a 2017 Basecamp
I had trouble getting the table off the pedestal
and solved the problem by adding a extra O ring to the table.
SSChameleon 06-07-2018 11:18 AM
I had an issue getting the table off the small posts after sleeping on them. I removed the post with the table attached, flipped it upside down on the cushion and put my knee on the bottom the table. Then I pulled up firmly with one hand while tapping the sides of the post with the palm of my other hand.
It took a little patience, and you don't want to hit the post so hard you damage it, but the post came out in under 20 seconds.
YoungishJedi 06-11-2018 07:09 AM
Great idea! I've been using a rubber strap wrench but this sounds like a better solution.
OTRA15 06-11-2018 07:20 AM
There have been a number of fixes posted for this. If you put “Basecamp table leg stuck” in the blue search box above, the results will show the fixes. Right now I can’t seem to post the URL.
Good luck,
Peter
OTRA15 06-11-2018 07:21 PM
PS -- FYI here is that URL for the search results:
https://www.google.com/search?q=base...=airforums.com
Goodgercan 06-12-2018 05:17 AM
I am his wife and I make up the beds and take them down! No taps or hits needed with the extra “O” rings. The tops just lift off. Easy pea set!
MrKenmore 06-13-2018 03:04 PM
I find it easier to remove the low table top with the post still screwed to the floor.
Lmnhead 06-17-2018 07:32 AM
Im interested in trying the extra O-ring solution. Our Basecamp is in storage, so would someone be so kind to tell me what size O-rings to order (or post a link)?
Goodgercan 05-15-2019 06:57 PM
I ring on Basecamp table
Order the same size O ring that came with the trailer
Lmnhead 05-16-2019 05:02 AM
Yeah, I posted that question 11 months ago and figured it out since. If anyone else is interested in trying out this solution, the product is 328 Silicone O-ring, 70A Durometer, 1 7/8" IN, 2 1/4" OD, 3/16" width.
We did not find that this solution was particularly helpful. The tabletops are still difficult to remove from the short legs. The extra O-ring maybe helps a little, but did not solve the problem in our case.
