-   -   Husky Center Line W/D (http://www.airforums.com/forums/f238/husky-center-line-w-d-181361.html)
GMarugg 05-10-2018 11:52 AM
My daughter bought her first trailer and will be making trips by herself. She is looking for a weight distribution anti sway systems. I was hoping some of you with more experience could give some words of wisdom. She would like a system that would allow her to back up and that is easy enough for her to work with. She is driving a 2015 Toyota highlander and pulling a Viking https://www.acresoutdoors.com/new-mo...17fq-26520654b She is looking at a https://www.etrailer.com/Weight-Dist...y/HT32216.html. Any suggestions?
CBWELL 05-10-2018 12:00 PM
I have used the Husky Centre Line for 3 years now and am very happy with it. Factory support is great, and is very easy to hitch up. The sway control works excellent. It is easy to back up with, however, it needs to be in a straight line to hitch or unhitch because of the way the sway control works. Not a big deal, and have had to take the sway bars off twice before backing in to a tight spot. Just hook up and pull out and be in a straight line to attach the sway bars if you have to hitch up at an angle. Some here will tell you that you need a ProPride or Hensley, but I feel just as safe with my Centre Line. JMHO
GCinSC2 05-10-2018 12:04 PM
Pretty sure husky has two models with centerline name. One has the spring piston heads the other a more conventional called TS.
Might want to specify model details.
rmkrum 05-10-2018 12:13 PM
Had a Husky. Was not satisfied with how it towed, particularly downhill. Gave it away, went to a ProPride. There are many other good choices discussed on the forums.
I don't have to be in a straight line to hook up under any circumstances with my setup. Considering that I tow a fairly heavy 22 footer with a fairly light Toyota Tacoma, the ProPride or a Hensley is my best choice. The sway prevention is mechanical by geometry of the hitch, and does not depend upon friction at all. The other BIG advantage is that I do NOT have to remove the heavy hitch head or WD bars when unhooking--just the stinger that connects the head to the receiver on the truck. The rest of the heavy hitch parts stuff stays on the Airstream's tongue once installed. WD adjusts via jacks and that is also minimal effort.
No, they aren't cheap. Used ones may be available from time to time.
PKI 05-10-2018 01:04 PM
Originally Posted by GMarugg (Post 2099678)
-- snip -- back up and that is easy enough for her to work with. -- snip --
RVing is special. Folks can enjoy the activity at many different levels. The common denominator is knowledge. The more you have, the safer and more cost effective your experience will be. So, my suggestion is to have her read the hitch related forums and develop sufficient knowledge to make the decision for herself.
We all have our own opinions, experience, fears and budgets. I know a fellow who has safely towed for three years. He has limited knowledge, but learns each year. He travels slow - 55 to stay alive. If that is not your daughter's plan, do not let her leave home without a Hensly Cub. They are available rebuilt for less than the $1500-$2000 list price. They are costly, but they work best. The cub is small trailer version of the Arrow or Propride PPP hitches.
You do not have to spend that much to get a hitch that controls sway. But you need to understand the good and the not so good issues about each design.
As a punt, have her get an Eaz-lift hitch with friction sway strut. She will have to adjust the friction when backing, but the unit is functional, flexible, and not expensive.
Good luck with the investigation. Pat
GCinSC2 05-10-2018 01:11 PM
Rmkrum,
Care to specify which model Husky?
Center Line with compression cylinders
Center Line TS (similar to equalizer)
Round Bar
Trunnion Bar
Curious.
Gary
rmkrum 05-10-2018 01:40 PM
Originally Posted by GCinSC2 (Post 2099710)
Rmkrum,
Round Bar
Trunnion Bar
Curious.
Gary
Nary a clue--when it failed to efficiently control sway on a local trip down a steep hill in the wind, it got yanked off, tossed into a corner of the garage, and eventually given away. Came with the rig from the original owner, and I only noticed the logo, sorry. Did not enjoy the white-knuckle ride one bit, and it was a pain to put it on and off, and re-assemble it each time it got used.
Was not a happy camper with it on the rig...research led me to the Hensley designs, and I went ProPride because it did not need any holes drilled to install the struts...and was a bit cheaper, with much better customer service. I'm in the process of upgrading to some prototype electrically powered WD jacks to make it even easier to use. Best part is NO disassembly required for normal use.
With the ProPride, have not had ANY sway, or near sway events, even when doing full power braking panic stops in Phoenix downtown traffic or being passed by big rigs that were doing 75-80 and passing way too close to me in West Texas during high winds.
GMarugg 05-10-2018 02:08 PM
Husky Center Line W-D
Attached is the Husky weight distribution system she is looking at. I appreciate all of the information provided. The group has a lot of valuable information
GMarugg 05-10-2018 02:18 PM
sorry for some reason I cannot get the attached picture to show up
GCinSC2 05-10-2018 02:22 PM
Nobody wants a white knuckle ride. For sure. They offer four models from a basic to a unique compression cylinder model but now we donít know which model you had.
Their compression cylinder model looks intriguing but the real issue is what works best for the OPís inquiry and situation.
rmkrum 05-10-2018 02:51 PM
Absolutely. And another very important consideration is the weight of the trailer, which we don't know yet. For a modest-sized trailer there are many systems that will work well.
I would be looking at how difficult it is to hook the hitch up, weight of the parts, and how much weight needs to be distributed as well. It's not a simple task by any means.
Me, I went straight to overkill, most likely, but I'm cool with that...no more white knuckles.
For the one the OP is looking at, study the assembly and hookup instructions to see how it is installed and how much force it takes to load the WD bars into place. That can be critical knowledge as to how well it can be used.
Also determine how hard it is to set up and PROPERLY adjust for the weight of the trailer and tow vehicle. That makes a HUGE difference in performance on ANY hitch design.
GMarugg 05-10-2018 03:05 PM
Husky Center Line Weight
Trailer Detail
Hitch Weight: 320 lb.
UVW: 2886 lb.
GVWR: 3635 lb.
CCC: 749 lb.
PKI 05-10-2018 03:10 PM
GM - that hitch is a clone of the Equal-i-zer brand hitch. Price is about 2/3s that of an EQ. It uses spring force to transfer weight and friction at the head and tongue support attachments to control sway. It is a stiff WDH by design. This type of hitch works well for some, but can be noisy, cause problems when backing and may bend the A-frame brackets.
You can get more info about the design concept by reviewing the Equal-i-zer hitch threads. Enter Equal-i-zer in the blue box above to the right.
The step down from a Hensley Cub is likely, a Reese dual cam, a Blue Ox, and an Eaz-lift. Pat
azflycaster 05-10-2018 03:21 PM
I switched from Reese last year to a Blue Ox SwayPro. Hitching up is pretty simple and it performs as advertised. Just my personal experience...
