-   -   Deadbolt with longer 4 & 3/4" bolt needed - Help!! (http://www.airforums.com/forums/f164/deadbolt-with-longer-4-and-3-4-bolt-needed-help-180567.html)
groovzilla 04-22-2018 07:03 PM
all,
i have a 1965 safari and the distance of the entry door handle is 4 & 3/4" from center to door edge/striker plate. **photo attached**
the deadbolt was missing so i located a new one to fill the hold but can't find an adjustable bolt or fixed bolt long enough that is 4 & 3/4" to fit my door.
**please help!!
groovzilla 04-24-2018 08:23 PM
**Correction ----> Deadbolt backset is 5" not 4 & 3/4
A W Warn 04-24-2018 08:32 PM
What brand is it?
Maybe something here>
http://www.directdoorhardware.com/5-...et-latches.htm
Contract Hardware in Auburn can get this for you, maybe have one in stock.
Glenritas 04-24-2018 10:13 PM
Check out http://www.vintagetrailersupply.com
A W Warn 04-25-2018 06:46 AM
Originally Posted by Glenritas (Post 2093600)
^^Good information^^ Thanks!
https://www.vintagetrailersupply.com...p/vts-343c.htm
In the reviews of this deadbolt there are photos of the install. Also instructions.
groovzilla 04-25-2018 08:39 AM
All - Thanks for the information - I'm familiar with Vintage Trailer Supply and they don't have the proper longer 5" bolt or as it is referred to "backset" for the door handle or deadbolt. They sell a deadbolt that gets mounted on the trailer wall next to the door which is what the longer "bolt" or "backset" is used for on their parts website - It has a round end on it which when locked goes into the door to secure it. I think this type of deadbolt looks ridiculous mounted under the window and next to the door and not on the door.
**When I googled 5" backset or searched 5" backset on ebay, i found several 5" bolts or backsets that will work. **--->I had been searching "longer bolt" which is what many in Airstream world refer to regarding the deadbolt or door handle longer "backset" which is why I had trouble finding one. It is called a "backset"
Kwikset makes both the 5" door handle extended 5" backset as well as the 5" deadbolt backset - I ordered both on Ebay yesterday.
Thx again!
Mx468 04-25-2018 09:17 AM
Go to Home Depot get a metal rod cut it to size and have someone weld it to the end of your lock. Thatís what I did.
