-   Modifications (http://www.airforums.com/forums/f345/)
-   -   Any ideas on locking batteries and propane tanks? (http://www.airforums.com/forums/f345/any-ideas-on-locking-batteries-and-propane-tanks-179755.html)
Cdn Camper 04-03-2018 07:24 PM
We recently purchased an Airstream travel trailer and store this at a RV / Boat storage place. While it is secured I have noticed that a few trailers have chain locks around their outside battery compartments.
I would hate to pick up the trailer and find the batteries gone and tanks removed - all very easy at this big site.
Any ideas on securing the battery cabinet and propane tanks?
GMFL 04-03-2018 07:29 PM
The battery box latch can be changed out to a key lock pretty easy and tank locks are available for purchase online.
For my tanks I just drilled a hole in through the large wing nut and the aluminum cross brace and put a padlock through the hole on both preventing the wing nut from being able to spin, thus locking the tanks in place
Ariz-Pacer 04-03-2018 07:43 PM
Locking batteries and propane tanks?
I have always locked my safety chains through the propane tanks collars.
That solves any problem.
AZP
DaveP 04-03-2018 08:00 PM
Try this product from Tork Lift for the propane tanks.
https://www.etrailer.com/RV-Locks/To...kaAkV3EALw_wcB
TSchleff 04-03-2018 08:07 PM
I don't know how long of time you leave your Airstream at the storage lot, but when I know I'm not going to be using the trailer for any extended period of time I remove the batteries so I can trickle charge them every 6 weeks.
PKI 04-03-2018 08:27 PM
If your storage lot is not secure, you may need to continue searching for a better solution. There is always a way to add a lock or at least make everything look more secure, but as mentioned here numerous times, a determined thief with a battery operated grinder makes quick work of locks, chains, and heavy metal devices.
There is a philosophy that car convertible owners develop. Leave it unlocked so the thief does not ruin an expensive top to access something of much less value. Never believed that approach, but understand it.
Fellow who sold me a boat had painted the outboard with primer and a splotchy pattern to make it look old. That too seems wrong for a nice shiny Airstream trailer.
Best idea may be to add a decent looking padlock, worry less, and replace what gets removed if such does happen. A good reason to use Walmart flooded cells or move your high priced spread inside the coach.
The really smart folks never park the rig long enough for bad people to find it. You are looking for a solution. That sounds smart. Travel safe. :) Pat
DRBusse 04-04-2018 09:19 AM
Check out immobilize.com They make a nice battery box lock and an Airstream-specific hitch lock.
kdinnar 04-04-2018 09:34 AM
Torklift Fortress
We got ours like DaveP said from eTrailer. Just make sure you get the version made for Airstreams. (Torklift Fortress Gaslock For Propane Tanks On Airstream) Easy to install and looks pretty solid.
Rocinante 04-04-2018 09:36 AM
We’ve decided that if someone steals our propane tanks, that will be our excuse to upgrade to aluminum tanks and buy one of those locks. ;)
VT Wanderer 04-04-2018 10:50 AM
After having 2 tanks stolen while in a storage facility a number of years ago, I purchased a Fortress Propane Tank Lock. I am very pleased with the way it works. As for the batteries, our AS's battery compartment came with a lock. My theory is: the locks are not fool-proof, but they may be an annoyance to a thief, and he/she may just choose to move on to an easier target.
PS the tank replacements were not cheap. There's the cost of the 2 tanks - the initial purging process - and then the fill.
james.mileur 04-04-2018 12:22 PM
Attachment 307839
Double nut x2, double big-o washer, chunk-o chain, UHaul lock. Done with gas bottles.
guskmg 04-04-2018 12:52 PM
If you chain secure propane tanks be sure and use a plastic covered chain. Quite often there is gas escaping due to pressure vent off or leaks. Any chain can produce sparks when moved. Adios!
guskmg
PKI 04-04-2018 12:56 PM
Is that another Pro for replacing the steel with an aluminum tank? Really must get some aversion theropy for these thoughts. :) Pat
Mollysdad 04-04-2018 02:24 PM
I hear the key lock for the outside shower can directly swap with the turn screw on the battery door.
My concern with any lock is it faces up into rain and road debris.
