-   -   Advice on bedding (http://www.airforums.com/forums/f240/advice-on-bedding-175026.html)
FlStrmr 11-14-2017 02:39 PM
Advice on bedding
Hey everybody. I have enjoyed learning through everyone's posts and am awaiting delivery on a 2018 Grand Tour with regular bed. Please share with my wife and I your solutions for making the bed more comfortable...foam toppers, etc.
Separate question...what do the rivets mean for some of you?
funkill 11-14-2017 02:47 PM
The smarter you are, the more rivets you get.
:lol:
Just kidding. I think it's based on the amount of posts you have on this site. Or how pretty you are....
Welcome. I use a memory foam topper on mine - but it's a gaucho/fold-out and the topper prevents me feeling the decorative buttons and trim on the cushions.
Cheers,
Airtandem 11-14-2017 02:58 PM
We converted from queen to twin. We use regular mattress with bamboo sheets and pillow case; cool in summer and warm in winter. Feel like silk. Thinking of adding topper.
mj
bankerhill 11-14-2017 05:10 PM
The key to our bed comfort has been two large sleeping bags. Very easy to lay out, easy to use, easy to pick up. With air conditioning in the summer and light use of the heater when cold, this works out very well for us.
busb2 11-14-2017 05:27 PM
Bed Midifications
I used 4 inch foam bedding and cut it into two 34 inch wide sections we covered each piece with a single bed fitted sheet to make two separate single beds that fit over the extended sofa and side seats. When we travel and camp, we generally leave the beds made up as we have the lounge model with the seating area up front and we would rather not remake the beds each day/night. However, if we want to use the rear seating area, it is easy to roll up the beds, secure them each with two shock cords, and put them behind the sofa. Without the foam mattresses we find the sofa bed to be very lumpy and uncomfortable although my wife can handle it better than me. We are very comfortable with this arrangement and we had tried several other arrangements before this since 2009, this being our third AI.
Protagonist 11-14-2017 05:43 PM
I've tried foam toppers. But for me they're too bulky and awkward to store when not in use (my Interstate is a 2012 model that's only 22'9" long, before they started making the EXT Interstates). To make the sofa/bed more comfortable, I removed the two upholstered wooden boards on the side-facing seats, since they were high-points that pressed hard into whatever body part happened to rest on them. That one modification made the bed infinitely more comfortable even without the foam topper.
Most of the time I used a lightweight double-bed-sized sleeping bag from Cabela's, rated for temperatures down to 40F, because I'll never let it get colder than that while I'm camping in it. But sleeping bags are too bulky to wash in my home washer and many coin-op washers, and too expensive to dry-clean.
So a couple of weeks ago I ordered a queen-sized RV SuperBag (https://www.rvsuperbag.com/), which is essentially a sleeping bag with removable and easily washable sheets. I also ordered a spare set of sheets for it. The SuperBag hasn't arrived yet, so I can't really say how well that will work. But I expect the SuperBag will be a significant improvement over the sleeping bag I was using up to now.
And for when it gets really cold (or at least for when I feel really cold, which isn't quite the same thing), I also have a fleece blanket I can throw on top for extra warmth.
Lily&Me 11-14-2017 07:18 PM
I use a comfy, cushiony mattress pad beneath, which folds up into a large pillow sham during the day, and an all season down comforter with duvet cover on top.
Wash the mattress pad and duvet cover as you would your sheets, works great.
The comforter stores easily in a cabinet.
Standard pillows also go into shams during the day.
Unconventional bedding, for an unconventional bed.
Keep it simple. :)
Maggie
Titus 11-14-2017 07:49 PM
We had a queen size foam topper shipped to the dealer where we bought the AI, and have used it since day (night) 1. There are just two of us and we always leave the bed down, so topper storage is not a problem. We have elastic straps diagonal at the corner of the fitted sheet and mattress pad and crossways on both, to keep things in place. On top of the sheet we have a comforter, and lay a sleeping bag on top of that when the temperature drops. We find that in the morning the temperature inside the AI is about 10 deg F warmer than it is outside. Before getting out of bed I reach up and turn on the propane switch (my addition) and turn on the furnace. Then I hide back under the covers until it the furnace brings the temperature up. I can still feel the cracks and the edge pieces of the side seats - and think the bed would not be very comfortable without the foam topper. The foam topper is not quite as long as the bed flip-down extensions. And the extensions do not quite reach the rear doors. So pillows slip off the topper onto the extensions, or off the extensions onto the rear floor on occasion.
Protagonist 11-14-2017 07:59 PM
That's why I removed those two upholstered wooden boards, AKA "edge pieces." Dips between the cushions are a lot easier to deal with than a thinly-padded wooden board sticking up higher than the cushions.
Pahaska 11-14-2017 08:03 PM
I modified the boards at the sides of the jack-knife seats by removing some plywood and adding foam to make up the difference. That made them unnoticeable.
I ultimately deep-sixed the couch and jack-knife chairs and converted to twins. Much better overall.
PianoManVan 11-14-2017 08:31 PM
Red Nomad, 3" California King memory foam topper is an exact fit for Grand Tour, I have a 2016. Roll it up when done and use two bungies to secure it, then lay it on the rail behind rear couch (see sideways pic). Wife and I sleep great with it, just like home.
glrosenbaum 11-15-2017 07:55 PM
My wife and I have the same question and no one seems to have a great solution. Im surprised that Airstream does not have a solution. We just purchased a 2016 GT EXT.
1973Argosy 11-15-2017 08:01 PM
Bought a new memory foam for the bedroom at home and cut the gentley used memory foam down to fit the Argosy. An electric carving knife slices through memory foam like a hot knife through butter fyi.....
GETRIDAONE 11-16-2017 04:33 AM
We started with 2" eggcrate memory foam and king size topper and sheets. The sheets were always pulling loose from the corners and at the bottom. It was a battle to get out in the narrow space at the bottom. I changed to full size sheets and topper which fit perfect across covering the seat and headboard drop downs. The sheet fits around the botom and stays tucked in. I used the extra foam inside the pillow shams for the jump seats. They are attached to the seat frame with tarp clamps so they don't move around. The extra room in the middle makes it much more convenient.
We always leave the bed made up while traveling. Some people like to put everything up during the day. In the end you will have to decide what works best for you.
TayaraTravel 11-19-2017 07:07 PM
Originally Posted by Protagonist (Post 2034588)
So a couple of weeks ago I ordered a queen-sized RV SuperBag (https://www.rvsuperbag.com/), which is essentially a sleeping bag with removable and easily washable sheets. ...
We use the SuperBag, no topper, and it works fine. We have recently discovered it is not warm enough when van temps drop below 60 (outside temps well below 50), so we are adding a fleece blanket, and a small space heater for when we are plugged in.
Lily&Me 11-19-2017 07:21 PM
Maybe consider an all season down comforter, which are incredibly warm.
Maggie
1st time RV 11-22-2017 01:52 PM
bedding
We have a Lounge version of a 2018 Interstate and we have been thinking about buying a 3" memory foam topper - put it on our wish list. Then my wife remembered we already have a queen size AeroBed so we just tried it. Fits perfectly in the space, a little high but that's ok. Nothing interferes with it. The "whoosh" deflate ability makes it easy to fold up and put away - fits in a bag about 18" x 24" And it's really comfy!
Pahaska 11-22-2017 02:04 PM
For those with twins
For our twins, depending on season, I use an artificial down comforter and/or a thin, fluffy blanket that I modified from queen-size pieces that I cut in half lengthwise. I bound the comforter cut edge with a tape binding. For the blanket, I simply rolled the cut edge and sewed a zig-zag seam down the rolled edge.
The resulting size is perfect for the 27"-wide twins with plenty of width to tuck in along the wall and hang over on the aisle-side. The tape on the slippery comforter helps hold it in place when tucked down along the wall.
Each item cost me only about $20 on-sale from Camping World.
Boxster1971 11-22-2017 04:50 PM
We use RV Super-Bags on our twin modified lounge bed. For colder nights my wife, an accomplished quilter, made me this quilt topper.
Attachment 299617
billramp 11-22-2017 05:12 PM
We have the same set up as Titus and have slept as much as five weeks straight with no complaints. We leave the bed set up when we travel.
