-   1966 - 1969 Ambassador (http://www.airforums.com/forums/f174/)
-   -   69 Ambassador Frame On (http://www.airforums.com/forums/f174/69-ambassador-frame-on-174382.html)
Dremel 10-27-2017 02:01 PM
My first post.
Iíve been lurking here for a while, and study study study.
I have finally jumped in to our 29 foot 69 Ambassador project.
My wife bought this before we met. If has sat outside at our place for 3yrs and a few at her place before that.
The floor is rotted at the front and back. And we decide to redo it.
Jhiner1978 10-27-2017 02:03 PM
Best of luck to you.
Dremel 10-27-2017 02:03 PM
4 Attachment(s)
Planning on a shell on floor replacement. Hopefully it will stay on that plan.
It is now gutted.
Only the water heater is still there. Looks like I have to take off some of the belt line in order to get it out.
Dremel 10-27-2017 02:04 PM
A New Home.
Move it into the barn so that I do not have to worry about the rain
Dremel 10-27-2017 02:05 PM
Removed my first panel
Dremel 10-27-2017 02:06 PM
All panels are out except the end caps.
Insulation was not a major mouse trap.
Things discovered.
Floor rot.
PO put down 1/8Ē plywood on the entire floor during some previous rebuild ( but did not fix the real floor )
Leaks at front and back windows. Water in the header.
A number of Olympic rivets in a few places used to fix something
A internal Rib was bent and out of place. Rivet holes filled with silicone.
Pics to come.
Next up is removing end caps, wires, water heater
Bubba L 10-27-2017 04:47 PM
Looks like a fun project. Having inside storage while working makes all the difference in the world. Donít throw anything away in the event itís unobtainable and take a lot of pictures. Good luck and enjoy. Bubba
Dingo Girl 10-27-2017 05:49 PM
I'll second the inside storage.
Good luck!
Dremel 10-28-2017 07:33 AM
Thanks, I'll be taking plenty of pictures as I go.
Yes, the inside storage will help a lot. Especially keeping the rain off when things like Windows are being worked on.
Dremel 10-30-2017 12:21 PM
Everthing is out. Including the end caps and the wiring.
I've done plenty of electrical, plumbing, basic house building, so I still feel comfortable. No expert, but comfortable. I've also completely rebuild a classic car, so all those experiancees, will help.
Dremel 10-30-2017 12:22 PM
Street side acoss from door, This rib is all out of wack. Guess the skin was pulled into shape, but left the rib.
Dremel 10-30-2017 12:27 PM
And the back where the Bath was, Full of Olympic Rivets.
Top three panels and the lower right ( from the inside ) must have all been replaced.
Will have to decide if to leave alone, or switch out to buck rivets.
I will be taking out all the windows and rebuilding them, so will have to choose olympic or buck for that also.
OK, next to search on how to rotate my portait pics.
Jhiner1978 10-31-2017 05:08 PM
Moving right along
