-   1978- 1979 Excella 500 (http://www.airforums.com/forums/f207/)
-   -   78 Excella Low Point Drain (http://www.airforums.com/forums/f207/78-excella-low-point-drain-174143.html)
bombard16 10-21-2017 07:44 AM
Is there a low point drain for the fresh water tank on my 78 excella 500? I have looked under it several times and can't find anything. It's rear bath if that helps.
4RXLA 10-22-2017 06:50 AM
Nope. Only way to drain fresh water tank is via the water pump.
Nhegel 07-01-2018 08:07 PM
Not sure if you still need help or not, but my 78 has a little door in the metal. It is right between the tires on the driver side. I pulled the original plug and installed a 1-1/2 (I think) pvc threaded plug, with the square "nut" going into the tank.
