-   1987 - 1989 Excella (http://www.airforums.com/forums/f209/)
-   -   Coleman AC Leak problem Solved! (http://www.airforums.com/forums/f209/coleman-ac-leak-problem-solved-17233.html)
Excellaphant 07-04-2005 07:45 PM
I'll give all the details here later, but I made a major discovery this
weekend and have solved a great mystery involving a persistant
leak that some Coleman AC unit owners experience.
I took my whole AC unit apart this Saturday and discovered that
someone installed the the drain pan directly under the evaporator
coil improperly. They put tape over the drain holes!
I've talked to a dozen people with this same problem, so if you have
a leaky Coleman, fear not. You can fix it with a Phillips screw driver
and a few hours.
More details here later,
