-   2011 - 2015 International (http://www.airforums.com/forums/f514/)
-   -   Replacement matress (http://www.airforums.com/forums/f514/replacement-matress-171626.html)
vdurbin 08-19-2017 09:18 AM
Replacement matress
Where is the best place to get a replacement mattress queen?
firemed509 08-19-2017 11:30 PM
We purchased a sleep number from camping world. We finished 4 week trip and it was so comfortable!
vdurbin 08-20-2017 06:25 AM
Thank you.
Ted S. 08-20-2017 07:27 AM
Had a custom mattress made from this place using our OEM mattress as a template:
https://themattressmaker.com
We went all out on quality and it is amazing. Heads and tails better then the original mattress.
Steamy1 08-20-2017 09:25 AM
I have considered a Sleep Number, but have been concerned about the weight and if you have to have shore power for it to work.
How does this work for you?
thanks,
Woosch 08-20-2017 09:49 AM
We got ours from Rocky Mountain Mattress.
firemed509 08-20-2017 09:51 AM
thanks,
Weight is not a issue it is lighter than the original. You do need power to inflate or deflate. Once you have your sleep number you really don't need to deflate unless you are travel from a low elevation to a high elevation. When we do that we deflate it to 50. It only take about 30 secs to inflate both sides. You can use your inverter or 110.
pteck 08-20-2017 03:23 PM
Order just about any foam/tempurpedic/latex/memory foam queen mattress online or amazon. As long as the dimensions are greater than the AS mattress. Then order an electric carving knife (~$15). Use your original mattress as a template to trace onto the new foam mattress. Trim as necessary. It will cut like the proverbial hot knife through butter.
I did this to replace my twins in my 27FB. Bought twin XL mattresses since the AS twins are longer than normal. Only had to trim the rounded corner. Then left the rest as normal. Mattresses are way more comfortable than the original.
