-   1970-79 Tradewind (http://www.airforums.com/forums/f125/)
-   -   Taillight assembly (http://www.airforums.com/forums/f125/taillight-assembly-169976.html)
Drought Buster 07-17-2017 08:51 PM
Taillight assembly
So in the 3 light assembly the inside lamp is a turn signal and brake light, the middle is a reverse light, and the outside is an 1157 bulb. What does this light do other than a taillight?
TG Twinkie 07-18-2017 07:09 AM
The 1157 bulb is a dual filament bulb. It is both the tail light and the brake/turn signal.
A close look at the bulbs filaments and you will notice one filament has a finer (smaller) gauge. This is the tail light. The filament closest to the top of the bulb has a heavier (larger) gauge. This is the brake/turn signal.
There should be 2 wires coming out of the base. You can test which is which with a 12 volt power source. The brighter one is the brake/turn signal.
Drought Buster 07-18-2017 07:23 AM
That is what I was thinking. The brake light isn't working on either side, so that gives me a place to start.
Drought Buster 07-18-2017 02:23 PM
Upon further inspection there is a wire that has either been cut or broken. This evening's project. :) Thanks for your knowledge!
Drought Buster 07-18-2017 04:49 PM
Any idea where the yellow wire goes?
Slats 07-18-2017 07:51 PM
I've always heard that yellow, containing the letter L, is for the left turn signal and green, containing the letter R, is for the right turn signal.
cliffcharb 07-18-2017 07:53 PM
Yellow is generally back up lamp
Drought Buster 07-18-2017 08:03 PM
It looks like the yellow was never hooked up.
Drought Buster 07-18-2017 08:07 PM
I don't see where the yellow wire should go.
TG Twinkie 07-18-2017 08:47 PM
Is the yellow wire connected to the light fixture?
Check to see if it is the brake/turn signal or the tail light by connecting it to a 12 volt source. If it is the tail light just connect it to the fixture on the right in the photo. Were you see the wire nut.
If it is the brake/turn signal you are probably going to have to do some digging in to the wire loom.
Drought Buster 07-18-2017 08:51 PM
It is for the brake light. The tail light works. I'll have to dive into the wire loom it seems.
