-   -   '16 Flying Cloud 25a heat pump condensate running down outer skin (http://www.airforums.com/forums/f427/16-flying-cloud-25a-heat-pump-condensate-running-down-outer-skin-166488.html)
majorairhead 05-07-2017 05:19 PM
Wow, I've searched, and read, and pondered.
We have what I believe to be a condensate tube exiting the driver side front wheel well of our 2016 flying cloud. It's a nice size tube, I'll guess an inner diameter of a half inch or more.
When we run our heat pump, water comes down the side of our airstream.
I'd like some clarification.
1.) Is heat pump condensate supposed to run down this tube or not? (I've read maybe not, possibly just A/C condensate)
2.) If heat pump condensate IS supposed to run down this tube, then what we may have is a warranty issue.
3.) Since I'm kinda handy, if there is an easy fix, please advise.
I have read about compressed air up.....compressed air from top down (though I'd like to know a detailed method how/where to access the condensate tube on our unit from the top.....stout trimmer line shoved up the tube, etc. etc.
Any help appreciated, I'd like to repair myself, but will tow to Ohio, or a reputable mid atlantic dealer that could fix, if necessary.
thanks,
majorairhead
AstroBruce 05-08-2017 06:24 PM
Both of my air conditioners in heat pump mode do the same thing. It is because the condensate is coming off the condenser in heat pump mode. The condenser drains on to the roof.
Bruce
majorairhead 05-08-2017 06:38 PM
Bruce
Thanks for your response Bruce, I truly appreciate it. I'm just totally not familiar with how the dometic ac works but am learning :)
