-   Electronics & Connectivity (http://www.airforums.com/forums/f317/)
-   -   1970 Control Panel Lights on all the time (http://www.airforums.com/forums/f317/1970-control-panel-lights-on-all-the-time-162598.html)
1970 Safari 02-11-2017 05:34 PM
So it has really gotten worse over the last year or so. The control panel lights for the black tank level, fresh water level, etc. come on when a light or the water pump draw current. Same thing happens when I go to check the level of the tanks by flipping the appropriate switch.
To get them to go off, I flip the water pump on and off OR the panel night light.
Any thoughts on what might be causing the problem OR what a suitable replacement set up might be using the existing sensors and wiring (and hopefully fitting in the same area) :o
1970 Safari 02-22-2017 09:51 PM
Wow, I thought someone would have a solution to my problem!!! But no responses!!! Have really "STUMPED" the Forum?!?!!?!?
Rob
Can of beans 06-30-2018 08:05 AM
It's most likely a bad ground
DremStremer 05-07-2019 08:07 PM
"1970 Safari" did you ever resolve the problem with your control panel? I have the same issue with mine, some of the tank level lights stay on all the time. It would be nice to have the control panel working again if possible.
Priska 05-15-2019 11:11 PM
Hi "DremStremer and "1970 Safari"
I have the same problem and would appreciate any help, as already said it would be nice to have it working.
In addition, it is on my to do list for this summer :-)
ke6gkv 05-16-2019 12:05 AM
hello. as another poster said, check your grounds. also use a volt meter the find out where the lights are getting power while they are on. your wires look good. would not hurt to touch up all solder joints. kurt
